turbo d15 issues
Old Oct 1, 2010 | 04:10 AM
lokiko's Avatar
Icon6 turbo d15 issues
Well, I got a freshly attached turbo kit on my eg civic, I'm making about 9lbs of boost, I let the car warm up, it runs fine, if I drive it conservitively keeping it under like 5k in rpm it runs fine, right after I boost, car runs like crap, the car lags like crazy, the pedal feels heavy, it will only run right if I floor it between stop signs, any ideas? I've got an fmu, and it smells like fuel in the car afterwards... any ideas?? Thanks
Old Oct 1, 2010 | 04:45 AM
wolve's Avatar
Default Re: turbo d15 issues
Originally Posted by lokiko
fmu
do these still exist
Old Oct 1, 2010 | 05:02 AM
EsotericImage's Avatar
Retired Moderator
No one uses FMU's anymore..
I dont know who peiced together your turbo kit, but some doesnt know what they are doing.
Your tuner (if you have one) shouldve realized and talked to you about what is wrong with your set up.
If this is an ebay kit you slapped on yourself, then this is just the beginning of your engine problems.
Actually, i doubt youll get a serious answer be cause of this.
https://honda-tech.com/forums/showpo...48&postcount=2
Old Oct 1, 2010 | 07:32 AM
Bizzle5OH3's Avatar
The lag could be because ur running way to rich. Ditch the FMU and get a chipped ECU and try getting it tuned, shouldnt be more than 125 bucks to have in dyno tuned!!
Old Oct 1, 2010 | 07:58 AM
lokiko's Avatar
Well thanks for all the input, seems like the main issue is the fmu so I have to find a way to manage everything without using it...
Old Oct 1, 2010 | 08:02 AM
Bizzle5OH3's Avatar
Get a chipped P28 ECU. I mean you can even get Hondata S100, its cheap, reliable and way better than an FMU
Old Oct 1, 2010 | 04:27 PM
Retired Moderator
Chipped/tuned ECU running neptune should be fine.. Crome is a cheap alternative..
Neptune is just as expansive and reliable as the S300.Just alot cheaper.
Tune with dyno runs $300ish..
Old Oct 5, 2010 | 10:10 AM
Bizzle5OH3's Avatar
300$ for a tune? Damn ur gettin ripped, 125 and hour for tunining at the shop I went to, if it takes for than an hour to tune, ur tunners got issues
turbo*s2k
Oct 2, 2014 07:02 PM
JuicedUpRice
Jan 6, 2013 08:54 AM
velisma
Sep 21, 2009 06:35 AM
924doorEG
Feb 24, 2008 06:26 PM
boostedeghatch
Oct 26, 2006 08:14 PM
