Turbo-D series ?
Old Apr 13, 2016 | 03:16 AM
ej8kid97's Avatar
Default Turbo-D series ?
So I have a 97 ex coupe with a d16y8 103k on it and I just got a turbo and down pipe with top mount manifold it's a t67 or t4 I believe maybe be the same but I was wondering how much boost can o hold on stock trans and internal I was thinking 6psi being the least and 8psi being the most but I'm not sure I don't know much about boosting cars I just have some knowledge.
Old Apr 13, 2016 | 04:45 AM
Ohmega's Avatar
Default Re: Turbo-D series ?
Don't focus on "PSI" as a goal. Set a power goal, and use as much boost as it takes to reach it. Stock internals should reliably hold at 200 hp, any further and you're risking your engine.
That being said, pick up a chipped OBD1 ecu and get it tuned once it's together. Running a stock ecu with boost is a recipe for disaster.
Old Apr 13, 2016 | 12:12 PM
Schister66's Avatar
Man U FTW
Stock d-series + Topmount + T4/67mm = lag for daaaays
That is in NO WAY a good fit for your setup. Stock D series safely cap out around 240whp meanwhile this setup is for something much larger than that (600ish?).
Read this: https://honda-tech.com/forced-induct...2A%2A-1024174/
Old Apr 14, 2016 | 05:43 AM
TheShodan's Avatar
Moderator
Old Apr 14, 2016 | 12:27 PM
ej8kid97's Avatar
Sounds good man thanks I appreciate it
Old Apr 14, 2016 | 12:39 PM
Schister66's Avatar
Man U FTW
Also, not all turbos are created equal. My post was to point out that the turbo you have is better suited on an LSx than on a D series, especially a stock one. If you're serious about turbocharging, first of all read the Forced Induction FAQ and secondly, look for small T3 framed turbos, not large frame T4 ones.
j.packsb
74
Jun 29, 2023 09:54 AM
j.packsb
Oct 15, 2009 06:58 PM
mikeunreal2
Nov 8, 2007 01:44 PM
hold your breath
Feb 8, 2007 09:59 AM
GroundZer0 336
Jul 13, 2003 07:15 PM
