Turbo cooling....
Old Mar 2, 2005 | 02:52 PM
andysila's Avatar
Default Turbo cooling....
can someone explain on how a turbo is cooled... i tried searchin but then gave up after trying a few times..
Old Mar 2, 2005 | 02:58 PM
beepy's Avatar
Default Re: Turbo cooling.... (andysila)
Turbos are cooled by oil, air, and water if so equipped.
Old Mar 2, 2005 | 03:02 PM
TurboB18C1's Avatar
oil or if it has coolant attachments then OIL and COOLENT, there are also oil coolers that are available if you are looking to cool a turbo setup but I would only recommend getting a oil cooler if you have a ball bearing turbo..
If your EGTS are high durring the cooldown period i would wait for it go down and then turn the car off becuase the high EGTS could seize your shaft or the bearings...
Old Mar 2, 2005 | 03:03 PM
EJ1 wilcox's Avatar
Default Re: Turbo cooling.... (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Turbos are cooled by oil, air, and water if so equipped.</TD></TR></TABLE>
Does the oil really "cool" the turbo? I thought it was just for lubrication?
Old Mar 2, 2005 | 03:14 PM
andysila's Avatar
Alright.. so now i know that its cooled by oil, water, and maybe coolant... now, which one is the most efficient?.. im thinking water but you guys probably know a lot more than me ..
Old Mar 2, 2005 | 03:16 PM
94lsboost's Avatar
Default Re: (andysila)
Ideally, run a ball bearing water and oil cooled turbo... you could even add a small oil cooler, but that would likely be overkill.
Old Mar 2, 2005 | 03:17 PM
beepy's Avatar
This is where you are going to find an argument develop. Of course water will cool a turbo better, but many think it is unessessary.
However, I use the water-cooling capacities of my T3, and I have had it for more than a year, without using a turbo timer or a cool-down period, and have zero leaks and no coking.
Old Mar 2, 2005 | 03:24 PM
andysila's Avatar
ive been recommended to run water cooling for the kit that im getting soon (full-race stage3 gt)..
Old Mar 2, 2005 | 03:27 PM
vtec.dc2's Avatar
Default Re: Turbo cooling.... (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">
oil cools the engine as well
Old Mar 2, 2005 | 03:28 PM
94lsboost's Avatar
Yes, you may get an argument, but water cooling is cheap insurance. Maybe you don't need it, but what if you do? It is easier to use it, keep your turbo A LOT cooler and be safe, than to lose a 800$ turbo... Cooler is better, bottom line.
Old Mar 2, 2005 | 03:30 PM
andysila's Avatar
so overall, your recommending water cooling? how would i be able to do that once i install my kit..
94lsboost's Avatar
Yes, I think nearly everyone will say do it. It entirely depends on your turbo though, if your turbo isn't capable of being water cooled then you can't do it.
Old Mar 2, 2005 | 03:39 PM
EJ1 wilcox's Avatar
Default Re: (94lsboost)
If you have a turbo that has a coolant jacket, then cool it... if not, don't worry about it...
I bought my turbo shortly after finishing "Maximum Boost", in which Corky Bell explains the benefits of water cooling the turbo...
when I ordered my turbo I had the option of water cooled or not... I ordered the water cooled turbo but didn't hook up the water lines right away because I couldn't find the right fittings... Just last weekend I got around to hooking up the water lines... I feel much better about it now, I used to wait about a minute before getting out of the car, now I wait less, which is nice....
I don't think there are any performance benefits to water cooling, but the lower temp will decrease coking and increase the life of the turbo, which is a good thing...
Old Mar 2, 2005 | 03:51 PM
andysila's Avatar
i see, thanks a lot.. just a quick question, is the "garrett GT35R Turbo" water cooled?
Old Mar 2, 2005 | 05:05 PM
miro_gt's Avatar
is it possible to water cool the turbocharger from a GReddy 15G kit ?
Old Mar 2, 2005 | 07:06 PM
scartail's Avatar
Default Re: (miro_gt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miro_gt &raquo;</TD></TR><TR><TD CLASS="quote">is it possible to water cool the turbocharger from a GReddy 15G kit ?</TD></TR></TABLE>
you've got to have coolant port in the center cartridge... if you don't.. then u can't.
Old Mar 5, 2005 | 03:35 PM
TurboB18C1's Avatar
well if the turbo is cooled with water. it will cause the car to run a little hotter since the turbo it self will be producing a lot of heat during operation and that heat will be transferred over to your water, as a result it will cause the car to reach its thermostat temperature a lot faster than before so your cooling cycles would be more rapid than before... but you are cooling the turbo down but heating up your water faster.
If I were in your shoes I would get a oil cooler (greddy,HKS,Blitz) it will help out the whole system buy cooling down the oil temp. If you are planning to road race with a turbo, it is a must to get the oil cooler since the EGTS will be real high.
sycamore
Oct 23, 2005 12:00 PM
afterburners
May 28, 2004 02:38 PM
clutch33
Feb 1, 2004 08:55 AM
mojord
Apr 26, 2002 10:20 AM
