Is my turbo done for?
Old Jul 19, 2008 | 06:31 PM
EKris's Avatar
Default Is my turbo done for?
Well, i was stupid, and couldn;t clock my turbo so i left it be. Which left the oil feed and drain on opposite spots. Oil drain was on top, and i wanted to see how that would do. I didn't even thnk that the oil could get backed up. Anyway, i didnt drive the car that much, and did not past 4k rpm. I took off the turbo today and there was oil in it, and i dumped it out, are my seals done? Or could I get lucky, and I just got the turbo just intime and there is oil in it bc it didn't drain?
Old Jul 19, 2008 | 07:49 PM
vtecb18c's Avatar
Default Re: Is my turbo done for? (EKris)
it sounds like you blew the turbo seals..does it smoke a lot?
Old Jul 19, 2008 | 07:54 PM
EKris's Avatar
Default Re: Is my turbo done for? (vtecb18c)
well it was smoking because it wasnt clocked right, but i took it off as soon as i knew it wasnt draining the oil like it should. I dont think the seals are blown, and think i saved it just in time. But i just wanted to ask.
Old Jul 19, 2008 | 08:00 PM
vtecb18c's Avatar
what turbo are you running? some rebuilt kits arent to expensice so i would replace the seals anyway
Old Jul 19, 2008 | 08:21 PM
EKris's Avatar
a precision gt3561e. Yeah i know, i dont know how to rebuild though.
Old Jul 19, 2008 | 08:28 PM
vtecb18c's Avatar
this might help...kinda vague though
http://www.gpopshop.com/hx35kit.jpg
Old Jul 19, 2008 | 08:33 PM
EKris's Avatar
vry vague. Lol
Old Jul 19, 2008 | 08:51 PM
ITR.#1446's Avatar
there is a rebuild thread in the top faq thread
Old Jul 19, 2008 | 09:51 PM
blinx9900's Avatar
Default Re: Is my turbo done for? (ITR.#1446)
clock it right, put it back on and let us know what happens...
Old Jul 20, 2008 | 07:10 AM
EKris's Avatar
Default Re: Is my turbo done for? (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">clock it right, put it back on and let us know what happens...</TD></TR></TABLE>
Def. The thing is, it's seized up sooo bad on the turbine housing, i cant clock it for anything. That is why i put it on and see what it would do.(stupid move i know).
Old Jul 20, 2008 | 07:43 AM
Flashmn's Avatar
yeah it seizes... I had to hammer my exhaust housing off :D
Old Jul 20, 2008 | 08:13 AM
EKris's Avatar
Default Re: Is my turbo done for? (Flashmn)
How did you hit it? I heated it up with those torches from Lowes, hammered with a rubber malet, and still didn't go. Did you hammer it to where the housing spins? Or did you hammer it to where it completely breaks off the center section?
Old Jul 20, 2008 | 08:24 AM
SovXietday's Avatar
I take it you DID loosen the bolts before trying to hammer it around?
Old Jul 20, 2008 | 08:26 AM
EKris's Avatar
Default Re: Is my turbo done for? (SovXietday)
yes, i loosened them to where i can spin them freely, heated it up many times, beat it, and it still didn't budge.
Old Jul 20, 2008 | 10:22 AM
Flashmn's Avatar
I hammered mine everywhere on the housing, inching it out...
Old Jul 20, 2008 | 11:50 AM
EKris's Avatar
well i tried it again with a buddy of mine, still didnt budge. F it.
Old Jul 20, 2008 | 12:47 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKris &raquo;</TD></TR><TR><TD CLASS="quote">well i tried it again with a buddy of mine, still didnt budge. F it.</TD></TR></TABLE>
have you tried using some WD-40 or anything like that? You must use the force young skywalker! but the turbine housing in a vice and pull from the compressor side if you must, sounds like a junk yard turbo anyways...
Old Jul 20, 2008 | 01:35 PM
EKris's Avatar
have you tried using some WD-40 or anything like that? You must use the force young skywalker! but the turbine housing in a vice and pull from the compressor side if you must, sounds like a junk yard turbo anyways...</TD></TR></TABLE>
Used PB blaster on it, didnt do anything. Turbo is not a junkyard one, it is a precision turbo.
Old Jul 20, 2008 | 02:20 PM
Flashmn's Avatar
screw the rubber mallet... get a HAMMER.
you wont get it out with a rubber mallet to begin with.
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKris &raquo;</TD></TR><TR><TD CLASS="quote">Turbo is not a junkyard one, it is a precision turbo. </TD></TR></TABLE>
yeah, like i said, junkyard turbo ...lol j/k sorry i don't like precision... On a more serious note how old is the turbo? was it purchased new or used?
Old Jul 20, 2008 | 04:50 PM
EKris's Avatar
It's used, but i got it from a reputable guy here locally. He's the one who tunes everyone's honda's. It's a good turbo, but the damn thing won't budge. I say [freak] it and ill be better off with an eBay turbo. LOL
Old Jul 20, 2008 | 04:57 PM
SovXietday's Avatar
Use a ford wrench. It is always a guaranteed fix for everything.
If you don't know what a Ford wrench is, it's a 5lb sledge.
Old Jul 22, 2008 | 01:54 PM
EKris's Avatar
Well a buddy of mine finally got it to budge. The turbine housing is off. My next question is.....Is there any way to tell if any seals are broken or gone out while the housing is off?
Old Jul 22, 2008 | 02:05 PM
Flashmn's Avatar
not really...unless you disassemble the whole thing, but I wouldnt recommend that.
Old Jul 22, 2008 | 02:09 PM
EKris's Avatar
ah ok. Well it looks to be in good condition still. Just a bit of oil and such from when i had it clocked wrong. I believe i saved it just in time. Just wanted to double check if i could see any problems and such. Thanks for info though.
josh0407
Apr 17, 2007 05:38 PM
nicktagz
Sep 10, 2006 07:38 PM
ludelvr
May 1, 2004 11:05 AM
Full-Race Henry
Oct 16, 2003 12:57 PM
