turbo car 120,000 miles?
Old 10-14-2002, 01:12 PM
12 oz.'s Avatar
Default turbo car 120,000 miles?
Modified by 12 oz. at 10:23 AM 11/11/2003
Old 10-14-2002, 01:30 PM
liam821's Avatar
Default Re: turbo car 120,000 miles? (NA Junkie)
i just got an interga LS for really cheap with 120,000 miles on it as a winter project car.
i plan on going FI with this car for next season and was wondering if it needed a rebuild.
i did a couple of searches and some people on here stated that they turbo'd thier car with 90+K miles on it.
i do plan to do a forged bottom end but will i need to do more?
give me some input if you have any. thanks
I would recommend you giving the motor a "freshin" up. Replace the rod bearins, and checkout the wear on the sleeves. Ive lost two engines to high milage, both over 120,000 miles...both spun the rod bearings.
Also how the engine was treaded in the past, and how you took care of it makes a big difference. My old stock motor at 100,000 miles, the cyl walls looked NEW. They still had the cross-hatch pattern on the sleeves!! Amazing.
So give the engine a looking over..inspect the rod bearings, and the rings. No use boosting on an engine thats going to blowup in a 1000 miles.
liam
Old 10-14-2002, 01:33 PM
boostedsol's Avatar
Default Re: turbo car 120,000 miles? (liam821)
the way the car was cared for previously is a major concern when force inducting a high mileage car. make sure to atleast get a 30k mile tuneup, replace your timing belt/water pump if you already havent, and a compression check wont hurt either. need more info before i ramble on. basically, if the car was treated good and all maintenance was done previously, you should be ok.
aeon117
06-24-2016 01:05 AM
area608EG
01-06-2008 08:44 PM
gmacarize
05-26-2007 02:30 PM
alterdcreations
49
12-22-2006 07:22 AM
Quick Reply: turbo car 120,000 miles?
