Turbo build advice
Ok currently I have a stock Ls turbo ef I'm gonna be moving to a semi built Ls vtec I wanna know what you guys think here's my set up now
Inline pro cast iron manni
T3t40e 60 trim turbonetics
2.5 ic piping coldside 2" hot side
Drag kit intercooler
560cc evo injectors
2.5 dp to 2.5 mandereal bent exhaust with 3" muffler
Walboro fuel pump
B&m fpr
Hers new set up goin in "Ls vtec
B18b block
81mm cp pistons 9:1
Eagle hbeam rods
Arp rod bolts
Acl race bearings etc
B16a2 head stock
Wat kind of power should I aim for and wat do I need to upgrade plz give me some ideas thanks h-t
560cc evo injectors
Walboro fuel pump
B&m fpr
B18b block
81mm cp pistons 9:1
Eagle hbeam rods
Arp rod bolts
B16a2 head stock
the b&m regulator hack will work for 400whp. you need to get bigger injectors, i only recomend Id1000's or fic1000's The 2.5" exhaust will be a restriction and the intercooler isnt realy capable of 400whp. intake temps will rise how much im not sure
How bout the inline pro log manni will it hold the pwr? Also will my turbo hold it? How do I find out my max hp rating for this turbo? Sorry for the boob questions guys ha
I dont think youll have a problem with the log, people have made more than 400hp on them. I loved my inline pro when I was using it. Im sure you can google t3 to4e turbonetics turbo and find some info from people using that turbo and see where theyre maxing out hp wise.
hotimportcrx
Sep 4, 2005 09:44 PM
