turbo, blown seals?
Old Dec 31, 2010 | 05:51 PM
b00stedOne's Avatar
Default turbo, blown seals?
I just bought a second hand turbo. I noticed that it is a little wet in one spot on the exhaust side. I blew air (with my mouth) in the oil feed line and plugged the oil return line with my finger. When I did this I could hear air slowly leaking from the exhaust side of the turbo. Would this be a "for sure" sign that the seals are blown?
Thanks
Old Jan 1, 2011 | 04:15 PM
b00stedOne's Avatar
Default Re: turbo, blown seals?
anyone?
Old Jan 1, 2011 | 10:17 PM
blwn95civic's Avatar
You cannot tell if the seals are bad by blowing through it lol
If there is oil in the hot side around the wheel then chances are it needs a rebuild. Is it a ball bearing turbo or journal bearing and how much shaft play does it have?
Old Jan 1, 2011 | 10:25 PM
b00stedOne's Avatar
its a journal bearing turbo (precision 6262). No shaft play. There is no oil on the turbine wheel or around it. Just a bit of black that would normaly be there.
I just figured, if air can leak around there, so can oil?? But I hope your right. Thanks for the help man.
Old Jan 1, 2011 | 10:31 PM
There arent actual seals in a journal bearing turbo. It works similiar to a ring on a piston, the only time Ive had a problem with oil leaking into the hot side is when the bearings were wore causing excessive shaft play.
TylerB
Sep 17, 2009 09:54 PM
AzntaggeR
Jun 17, 2005 11:07 AM
jdmcivic1999
Feb 12, 2005 04:05 PM
QuickHonda
Apr 17, 2002 08:11 PM
