Turbo blew up on itself!
well kinda. the oil seal suddenly took a ****. i guess i knew it was on its way out, cause it used to smoke real badly until i put a restrictor and catch can on the motor. it barely smoked at all now.
until yesterday morning. on the 5 mile trip home, i went through alteast a quart of oil!! i was leaving a smoke screen behind me!. you could see oil coming out of the turbine housing and down pipe and there is a sweet coating on the inside of dp, like an 1/8 in thick. oil even dripped out of the back of the exhaust when the front end was up in the air!
it seems to have blown out of the comp seal as well, as there was a good amount of oil in the compressor housing and in pre-ic charge pipe, like enough to make a puddle after i set it down. but there is no oil post-ic and none really in the ic.
also its a liquid cooler center section and the oil in the turbine housing was milky looked like there was coolant in it, but there was no coolant in the motor oil and no oil in the motor coolant. and after psuedo pressure testing the coolant passages and oil passages, i cannot find them leaking into each other.
has this ever happened to anyone else? comments, suggestions, questions??
i will be rebuilding it with a staggered oil seal this time.
thanks
thanks
Who is Mr Robot?
Re: Turbo blew up on itself! (bdavis)
you sure its an aireasearch... the garrett internals makes me think its an ssac because garrett and airesearch are the same company....
Re: Turbo blew up on itself! (wantboost)
yea its got it stamped on the side. its the one i had posted a while ago when i was trying to figure out what it was. you actually gave me some insight
https://honda-tech.com/zerothread?id=1498225
its not one of those POS ebay ones.
this was strange though, just all the sudden, kaputt!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">it happens sometimes. </TD></TR></TABLE>
yea, ill just rebuild. but the whole coolant and oil looking stuff in the turbine housing makes me wonder if all will be good.
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdavis »</TD></TR><TR><TD CLASS="quote">yea, ill just rebuild. but the whole coolant and oil looking stuff in the turbine housing makes me wonder if all will be good.</TD></TR></TABLE>
the chra could have cracked from years of abuse, id have it checked
anyway i can check myself?? maybe ill try running water through it and see if it seeps to the other side. i dont really know how i can pressurize it
scubacamper
03-24-2016 10:24 AM
