turbo/b18b built up
Old Jan 26, 2005 | 03:50 PM
not2night's Avatar
Default turbo/b18b built up
HELLO, I WAS WOUNDERING WHAT WOULD BE THE MOST EFFECTIVE AND EFFIECIENT WAY TO BUILD A B18B FOR TURBO? WHAT WOULD I NEED TO DO TO THE MOTOR FOR ABOUT 20LB OF BOOST. I HAVE 4K TO WORK WITH, I ALREADY HAVE THE MOTOR. IT WILL BE GOING INTO A SLEEPER EG CIVIC SEDAN. HOPING TO RUN ABOUT 12SEC IN A QUARTER. ANY INFO WOULD BE GREAT (ESPECIALLY FROM THE PROS).
Old Jan 26, 2005 | 03:57 PM
JdmEKCivic's Avatar
Default Re: turbo/b18b built up (not2night)
Well I'm not sure if that 4k includes the turbo kit but if not , some forged internals, bigger injectors, block guard, and some sort of EM (like hondata, Uberdata etc..) and some good tuning.
Old Jan 26, 2005 | 05:03 PM
Dunc's Avatar
BCICAN
Default Re: turbo/b18b built up (JdmEKCivic)
If you manage to run 20psi for under 4k (safely), let me know how you did it. Say the turbo kit is 3k, hondata+injectors+fuel pressure regulator+3bar= say 1k, tuning say 300, sleeves say 1500 (safety), rods and pistons 800=$7600 (not to mention any labor for pistons and such.
Old Jan 26, 2005 | 05:09 PM
underpressure02's Avatar
search seriouly this is always asked. What is with all the noobs asking the same questions over and over.
AND TURN YOUR DAM CAPS LOCK OFF.
Old Jan 26, 2005 | 05:31 PM
vaporboy12's Avatar
Default Re: turbo/b18b built up (underpressure02)
yeah do a search and i say that $4000 is a good amount. unless u have connect with parts and or buying used but hey good luck with that one
Ri5e's Avatar
Stock block is sufficient for 11-12 seconds...
Old Jan 26, 2005 | 06:13 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
you can go low 12's on a stock b18a/b its not hard just get a good turbo setup and a good tune
Old Jan 26, 2005 | 06:59 PM
Boring's Avatar
Default Re: turbo/b18b built up (TURBO BLUE HATCH)
I have a B18a fully built and was turbo but im parting it out if you want any of these parts let me know.
ZDyne Gold S-ECU,JE 9.2:1 Pistons,Eagle H-Beam Rods,STR block guard,ARP Head Studs,EF1 L21 cams,Skunk 2 Intake Manifold,Skunk 2 Cam Gears, DSM 450cc injectors,B&M FPR,Brand new seals/bearings/timing belt/water pump/type r oil pump
jakoh77
Sep 29, 2011 05:01 AM
not2night
Jan 23, 2005 07:09 PM
Rob!
Jan 5, 2005 07:02 AM
H22CL
Sep 22, 2004 05:45 PM
dmotoguy
Dec 25, 2002 11:40 PM
