turbo b16 fuel pressure
Re: turbo b16 fuel pressure
if its tuned the fuel pressure should have already been adjusted accordingly. If you mess with it after being tuned, youre going to need to get it retuned.
40-45 is okay. im also running 1000's. but im all motor with my injector duty cycle turned down. but yea between 40-45 is okay. get an AEM air fuel ratio setup so you know if your lean or rich.
oooo gotchya ya i had figured stock was around 44, with turbo they might have uped the fuel pressure so i was running it cloe to 50, took it around the block and it was sounded real loaded up and bogish, also was spittin alota **** outa my open dump pipe off the waste gate,
stock is a base pressure of 38 with the line off. hella lean lol. mines at 42-45idle-50wot. your tune will provide all the fuel you need. money should have been spent otherwise
milds3vn
Northeast (Sales)
08-08-2005 08:27 AM
