Which Turbo !!!
Old Sep 20, 2006 | 01:45 PM
9civichatch3's Avatar
NICE GUY
Default Which Turbo !!!
I plan on making 250whp on a B16.
One friend says the GT28RS is too small and the power will fall off at high RPM and to go with T4/T04E. Another friend says the GT28RS is a great turbo to make 250+ whp and will not fall off at higher RPMs. I have researched and they say go with the Garrett GT28RS.
Which one would you choose !!
Old Sep 20, 2006 | 04:47 PM
HiProfile's Avatar
Default Re: Which Turbo !!! (9civichatch3)
http://forums.evans-tuning.com...=1391
D16s loost power much quicker/easier than b16's, so keep that in mind. I'd rather have boost fall off a bit near the end in exchange for much quicker (1000 rpm) spool up.
http://forums.evans-tuning.com...=1559
If this stock gsr can keep the torque up, I wouldn't see why you'd want a t3/t04e, besides lag-induced traction control - and price.
http://forums.evans-tuning.com...=2018
This LS does a great job for nonvtec...
All said, 250whp is 250whp, you would just need a bit more boost if it was to fall off. The gt28rs is good for ~300whp max (honda w/pump gas), the t3/t04e 50trim for ~350whp, the 57trim for ~400whp on a b16. Just be realistic with your goal, and pick the turbo with the max closest to that goal.
Old Sep 21, 2006 | 08:53 AM
TheHooded_Mike's Avatar
Default Re: Which Turbo !!! (HiProfile)
A t3/t04e is like $500 cheaper than the gt28rs for one thing, and has significantly more power potential. Even a t25 could make around 250 and cost wayyy less. The answer is very clear imo.
Old Sep 21, 2006 | 09:24 AM
NICE GUY
Default Re: Which Turbo !!! (TheHooded_Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheHooded_Mike &raquo;</TD></TR><TR><TD CLASS="quote">A t3/t04e is like $500 cheaper than the gt28rs for one thing, and has significantly more power potential. Even a t25 could make around 250 and cost wayyy less. The answer is very clear imo. </TD></TR></TABLE>
Its cheaper, yes, but the GT28RS is capable of more power as well, with a little modification.
Old Sep 21, 2006 | 09:30 AM
Okay, but you're the one who said you only wanted 250 so...
Old Sep 21, 2006 | 09:35 AM
NICE GUY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheHooded_Mike &raquo;</TD></TR><TR><TD CLASS="quote">Okay, but you're the one who said you only wanted 250 so...</TD></TR></TABLE>
Thats all i want to make !! It just sounded like you were saying the GT28RS couldnt make more power !
Old Sep 21, 2006 | 09:49 AM
Well it sounds like you're set on the rs, so what is your question then? The fact is that both can make well over 250, but one is $500 less, so I don't see why you wouldn't want to save some money. Is spool your concern? Because a 50 trim would spool nicely...and is this just a daily driver or what?
Old Sep 21, 2006 | 09:53 AM
Bfreeman's Avatar
how come only 250??
me personally on my car i have an SC50 i kinda like it my car stock internal B16 makes about 250-260 just doesnt seem like enough power after driving it these lsat few months but i remember i said i just wanted 250 now im fixing to upgrade to a sc61..then build and shoot for 350-375.
Old Sep 21, 2006 | 10:03 AM
NICE GUY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheHooded_Mike &raquo;</TD></TR><TR><TD CLASS="quote">Well it sounds like you're set on the rs, so what is your question then? The fact is that both can make well over 250, but one is $500 less, so I don't see why you wouldn't want to save some money. Is spool your concern? Because a 50 trim would spool nicely...and is this just a daily driver or what? </TD></TR></TABLE>
Its my daily driver. The RS just seems to be a all around better turbo for what im looking for. Newer, quicker spool, capable of making more power if needed (rated for 320hp)
Old Sep 21, 2006 | 10:05 AM
NICE GUY
Default Re: Which Turbo !!! (Bfreeman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bfreeman &raquo;</TD></TR><TR><TD CLASS="quote">how come only 250??
me personally on my car i have an SC50 i kinda like it my car stock internal B16 makes about 250-260 just doesnt seem like enough power after driving it these lsat few months but i remember i said i just wanted 250 now im fixing to upgrade to a sc61..then build and shoot for 350-375. </TD></TR></TABLE>
Hopefully 250-260 should please me. (fingers crossed)
Old Sep 22, 2006 | 04:26 AM
Schister66's Avatar
Man U FTW
If you want a fun daily driver, the GT28RS would be a great turbo for you. It is small and limited to about 320whp on an unbuilt bottom end. If you went with a T3/T04 setup you could make more power out of it, but you will lose the low end power. I have a 60 trim on my GSR and i get boost around 4500rpm with a log manifold. Also, on 9psi i make 275whp which is enough to have some fun....
Old Sep 22, 2006 | 04:53 AM
Speed Infliction's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9civichatch3 &raquo;</TD></TR><TR><TD CLASS="quote">
Hopefully 250-260 should please me. (fingers crossed) </TD></TR></TABLE>
you will like it then you will want more. get something that you can upgrade in the future because you will want to. If you don't believe me then thats your problem.
Old Sep 22, 2006 | 10:02 AM
NICE GUY
Default Re: Which Turbo !!! (Speed Infliction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Infliction &raquo;</TD></TR><TR><TD CLASS="quote">
you will like it then you will want more. get something that you can upgrade in the future because you will want to. If you don't believe me then thats your problem.</TD></TR></TABLE>
OK, the GT28RS is capable of being upgraded, but I guess thats just my problem !!!
Old Sep 22, 2006 | 10:16 AM
WickedHonda00's Avatar
I'm about to build a turbo motor and piece together a turbo kit. From what I understand from alot of people is that you'll always want more power. Is this so? I don't want to buy a turbo just to find that 3 months later I want more. I was thinking about an SC60-1. I was told that these were a good purchase for making sick power levels while retaining a good streetable powerband. Since my head is going to be ported, I figure I'll be able to see boost atleast another 500rpm sooner than the typical rpm for that turbo on a b16. The head will flow 320+CFM. Let me know what you guys think. (This could help the original poster in a way)
93first1
Apr 5, 2006 05:12 AM
EJ8 GSR-T
Feb 17, 2006 11:09 AM
BLKCRX
Apr 23, 2003 01:13 AM
ASHY-ELBOW
Nov 4, 2002 10:15 PM
Ri5e
Mar 22, 2002 03:58 PM
