Turbo+ 11:1 compression.
Old Dec 2, 2001 | 02:22 PM
OneThirtyEight's Avatar
Default Turbo+ 11:1 compression.
ok, Im really looking into the possiblity of getting a turbo very soon. I just had my motor rebuilt, port/polish, ITR pistons, crower dual springs, ti retainers, rebalanced, venom intake manifold, AEM rail, 280cc injectors, ACT clutch, new valves, guides, ect ect.
Anyways Im looking into getting a turbo. What is going to be the deal with my compression. Its around 11:1. Im very worried about this, anyone have any opinions aside from using a hondata?
[Modified by 97blackteg, 6:29 PM 12/2/2001]
Old Dec 2, 2001 | 02:27 PM
integRated109's Avatar
Default Re: Turbo+ 11:1 compression. (97blackteg)
your boost will be limited. i just burnt up some rings on 8psi, so ill be dropping compression.
Old Dec 2, 2001 | 02:29 PM
Default Re: Turbo+ 11:1 compression. (integRated109)
im not planning on running anything over 6psi. Would this be safe with an ingition and upgraded injectors?
D-SPEED's Avatar
more careful tuning will be required. as integrated said, boost will be limited. I would look into cometic headgaskets
Old Dec 2, 2001 | 02:31 PM
D-SPEED's Avatar
you could do it without either, although both are always a good idea.
Old Dec 2, 2001 | 02:33 PM
Default Re: Turbo+ 11:1 compression. (D-SPEED)
Thing is id rather not have the head pulled again if I can avoid it.
Old Dec 2, 2001 | 02:36 PM
should have no problems at 6psi, but you wont stay there long. boost really is an addiction. its hard to say no with all that power just a twist of the profec away.........
Old Dec 2, 2001 | 02:38 PM
hehe if I know im safe at 6psi I have no desire to blow up my engine, I can handle keeping it there if thats safe.
Old Dec 2, 2001 | 02:44 PM
thats what i said if it wasnt for that pesky GS-T on 18psi.
i may be broke, but i beat his a$$
Old Dec 2, 2001 | 02:45 PM
LOL
Old Dec 2, 2001 | 03:09 PM
Mike D's Avatar
i think you will be fie at 6 psi. But like mentioned you will need more careful tuning. But even though you are only running 6 psi you will still make some really good numbers.
Somone, cant remeber who, had an itr with teh drag kit at 6 psi and he was somewhere around 280-300 whp. It was a member on HA.net, Hella Yella it think his name was.
good luck
Old Dec 2, 2001 | 03:48 PM
Tapp's Avatar
New User
Sounds like you just bought a bunch of parts, you need a plan...
Old Dec 2, 2001 | 04:02 PM
D-SPEED's Avatar
Default Re: Turbo+ 11:1 compression. (Tapp)
exactly. planning is key when building a car
Old Dec 2, 2001 | 04:09 PM
DRAGLS's Avatar
Hey javier at jg runs turbo motors at that compression u know its all about the tuning, u want something reliable get a standalone and tune it real good and u will be pulling over 400 to the wheels real safe.
Old Dec 2, 2001 | 04:12 PM
SIK IN DA HED's Avatar
New User
Default Re: Turbo+ 11:1 compression. (DRAGLS)
high compression... hmmm like everyone says... limited boost potential because of the possibility of blowin your motor.
99siRACER
Jan 3, 2012 12:20 AM
MyEGisBad
Jan 19, 2011 10:12 AM
MobRacing2
Feb 24, 2006 06:43 AM
nah22accord
Feb 2, 2006 07:57 PM
