how much power is the integra LS 90 fuel pump good for?
Old 05-27-2003, 11:10 PM
kahren's Avatar
Default how much power is the integra LS 90 fuel pump good for?
i will be goign with 450 cc injectors on a turbo LS
power output will be close to 200 at wheels, do i have to upgrade the pump
to keep that 40 or so psi at the rail, or will the stock pump keep up?
Old 05-28-2003, 05:29 AM
blackteg's Avatar
Default Re: how much power is the integra LS 90 fuel pump good for? (kahren)
Check my sig, stock pump but it leaned out a lot at the topend. Not sure if its because of the pump or the fact thats its not tuned.
Old 05-28-2003, 07:01 AM
Boost2NA's Avatar
For what you want with the set up id say the stock will hold. But why even question the stock one . You can pick up a 255lph walbro for around 100 bucks. That would be a $100.00 well spent. Dont take any short cuts at all when it comes to fuel!!
Old 05-28-2003, 11:22 AM
blackteg's Avatar
Default Re: how much power is the integra LS 90 fuel pump good for? (Boosted99Si)
I can understand where he is coming from though. The tank has to be dropped to replace it, major pain in the ***.
Old 05-28-2003, 10:46 PM
kahren's Avatar
Default Re: how much power is the integra LS 90 fuel pump good for? (blackteg)
the car who i am building for is ona real budget, i am trying to go with the OEM stuff from other manufacturers to keep the costs down. as far as the injectors are concerned are teh stock dsm the best ones to go with with the resistor box, or is there somethign better.?
Old 05-31-2003, 04:21 PM
kahren's Avatar
so no one knows?
Old 05-31-2003, 04:58 PM
blackteg's Avatar
I don't know if they are the best but they work pretty well. I run them and have had no problems with them at all.
Old 05-31-2003, 05:15 PM
kahren's Avatar
how much power is the stock 91 integra pump good for
at 12:1 afr?
Old 05-31-2003, 07:42 PM
spike's Avatar
what about going with a turbo dsm pump? direct fit pretty much for a honda.. that's what I plan on running. My friend runs one now. Anyone know any problems with doing this? plus you can pick one up for like 20 shipped on dsmtrader
Old 05-31-2003, 09:56 PM
kahren's Avatar
Default Re: how much power is the integra LS 90 fuel pump good for? (spike)
i have heard from dsm owners that their stock pump sucks, but i donno how much they know anyway so...
ElswickB22
03-06-2014 08:04 PM
ahmongboi
03-27-2010 06:10 AM
tron-R
07-13-2007 04:31 PM
rkostone
03-28-2006 01:48 PM
Junkyard2000
11-09-2005 06:37 PM
Quick Reply: how much power is the integra LS 90 fuel pump good for?
