Tuning Troubles, TE Cells Maxed in VACUUM 5.96 Highest? Need
I want a CRX tattoed on my butt
Running Turboedit 2.6.1, 88 crx si with a d16a6 motor, dsm 450's and a gm 3 bar map sensor.
Im just getting around to tuning the part throttle, everything is pretty much mint but one spot in -11 to -12 vacuum where the a/f's read about 18:1 and the car bucks.
Now in TE, in those cells, the number is 5.96, thats the highest number that it will let me put in those cells and I cant adjust it.
http://putfile.com/pic.php?pic...s=f10
What do I do?
heres a pic of my bin if anyone can help me. I will email the .bin file to you if you think there is something you can do for me, maybe it needs to be run on a different version or scaling or something.
Thanks
What do I do?
Thanks
Re: Tuning Troubles, TE Cells Maxed in VACUUM 5.96 Highest? Need (PINKS)
I think its weird that you can't add some fuel there. You can try to pull a little timing, at the area you have highlited your at 30 some degrees. Just a thought
<<<< still learning tuning
Checked some of my uber maps, and timing looks similair there, so likely not the issue.
Your fuel map is your high map. Your ignition is your low map, whats your low fuel map look like??
K20EF8Dx
Engine Management and Tuning
12
08-03-2012 03:06 PM
