tuning off of the spark plug
Old Apr 26, 2005 | 08:31 AM
mattssi's Avatar
Default tuning off of the spark plug
I am interested in obtaining some info in tuning a turbo'd honda off of the spark plugs. Right now i a running a basemap-uberdata. I cannot afford to get a wideband, But have everything else. I will be getting one soon, but funds are tight. I know that tuning off of the plugs is not the best way, but it is more accurate than just using a basemap. Any direction would be beneficial. thanks
Old Apr 26, 2005 | 09:29 AM
mattssi's Avatar
Default Re: tuning off of the spark plug (mattssi)
bump, anybody have any input.
Old Apr 26, 2005 | 10:04 AM
JDogg's Avatar
you can, but the problem is you may fry something and onlyl know b/c you see detonation on the plugs, or even pre ignition from running too lean. time you stop the car, pull the plugs the damage has already been done. use the pplugs to make sure the tune is good, not to do all the tuning.
Old Apr 26, 2005 | 10:27 AM
Treblarefils's Avatar
Ill tell you from my experience.. I was running uberdata basemap for maybe 40 miles and reading plugs every drive, always read rich. Never heard any bad noises and car ran great. Since i dont need to drive the car it was mainly to test my work in those 40 miles and to see if everything worked properly fully boosted 1st gear only 3 times at 7psi. Wideband was on order to do some tuning plugged in wideband and was idling in the 10s A/F ratio super rich in vacuum and only hitting 13s high 12s A/F in boost not overly bad but not rich enough for me. So i would reccomend getting a wideband. Basemaps will make the car run but need to be checked as soon as you can.
Clifnotes: car ran way too rich in vacuum and too lean in boost off uberdata basemap.
hksitr
Sep 12, 2011 03:03 PM
PBsTREETracer
Apr 12, 2008 06:39 PM
buddy4002
Feb 7, 2006 11:04 AM
Evil EG
Sep 20, 2002 10:59 AM
ALLMOTOR18
Sep 10, 2002 03:05 PM
