Tuning and nitrous
Old Feb 21, 2006 | 12:48 PM
Azn Kenny's Avatar
Default Tuning and nitrous
I have a '96 LS Teg that I recently converted to OBD-1 and tuned it with CROME. We hooked up a wideband and used the Ostrich from Moates. We didn't touch ignition, only tuned the fuel map so I now have close to 13.8-13.9 a/f ratio all throughout the powerband. It was a definite improvement.
I just bought an n2o kit as well as NGK BKR7E (colder) plugs and an adjustable fpr from B&M.
Nothing is installed yet but after I put in the plugs and hook up the fpr, I plan to retard my timing by 2 degrees. So my question is, should I retune my car after these mods and the retard timing or keep the same fuel map as is? I want to run nitrous safely and I know my car will probably run like crap with the plugs and extra fuel so shuold I try and tune it and lean it out?
Thanks guys.
Modified by LSntegra at 7:23 PM 2/22/2006
Old Feb 21, 2006 | 01:06 PM
Soccerking3000's Avatar
Default Re: Tuning and nitrous (LSntegra)
uhh from my understanding you dont want it to be at stoich while at WOT i would tune it at around 13.5-13.8. Is it a wet kit?
Old Feb 21, 2006 | 01:28 PM
Azn Kenny's Avatar
It's a 50 shot dry, I may move on to a 75 later on down the road.
Old Feb 21, 2006 | 01:38 PM
Default Re: (LSntegra)
i would defiantely ditch the dry shot or at least convert it to a wet shot it makes things much easier. I know a few companies make the conversions kits realitively cheap
Old Feb 21, 2006 | 02:21 PM
Azn Kenny's Avatar
How does it "make things easier"?
Dry shot is easier to install then wet, not much of a diff I guess though.
If you mean safer to run a higher wet shot then I agree.
Old Feb 21, 2006 | 02:30 PM
because if this a daily driver and you are running a dry shot have it tuned for a dry shot it will run pig rich all the time, while if you had a wet shot you could tune the car when not on nitrous and when nitrous is engaged all you need to do it have the appropriate fuel jet in there and you wont lose the ability to drive it normally...
Old Feb 21, 2006 | 04:03 PM
Azn Kenny's Avatar
Ok thanks, good advice.
Old Feb 22, 2006 | 12:13 PM
JSpin's Avatar
can't believe nobody has said anything........if you're car is that lean at WOT, your gonna seriously hurt the motor, and you're defnitely down on power.
Old Feb 22, 2006 | 03:22 PM
Azn Kenny's Avatar
Sorry that was a typo.
At wot, my a/f was around 13.8-13.9, that's not that lean.
Old Feb 22, 2006 | 04:02 PM
Default Re: (JSpin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpin &raquo;</TD></TR><TR><TD CLASS="quote">can't believe nobody has said anything........if you're car is that lean at WOT, your gonna seriously hurt the motor, and you're defnitely down on power.</TD></TR></TABLE>
i said that in more first post,mind you he isnt boosted so a 12:1 a/f isnt needed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">you dont want it to be at stoich while at WOT i would tune it at around 13.5-13.8.</TD></TR></TABLE>
Old Feb 28, 2006 | 08:34 AM
7rrivera7's Avatar
Default Re: (Soccerking3000)
I'm going to run a ZEX dry kit and the computer (ZEX box) handles fuel enrichment via vacuum. This will allow me to tune for NA and when on NOS, the ZEX box will richen up the mix.
Is this a safe alternative?
Old Feb 28, 2006 | 08:39 AM
Default Re: (7rrivera7)
no, it raises the fuel pressure essentially making it an fmu and we all know how good those are. AT THE LEAST get a wet kit unless you are running a standalone with a fuel map just for nitrous...
DA9kid
Jan 1, 2007 04:50 PM
Azn Kenny
May 14, 2006 08:32 PM
tmekjian
Jun 11, 2003 11:35 AM
sicklexus1
Jan 29, 2003 03:30 PM
integra1884
Jan 6, 2003 07:26 PM
