Tuned Finally!!
Old Aug 26, 2005 | 07:05 PM
-Trinitron-'s Avatar
Default Tuned Finally!!
Took the heap over to Ed at Balanced Performance in Atlanta. Here's the setup and what happened.
-STOCK B16 - ITR intake manifold
-Inline Pro Mani
-Tial 38mm controlled by Profec B
-Garrett T03/04e .54/.63
-DSM 450's
-UBERDATA
The Uberdata base map on 7 psi was good for 219whp/155ft.lb.
Got the fuel corrected and got:
235 whp/158 ft.lb. @ 7 psi
299 whp/199 ft.lb. @ 11 psi
When I pieced the kit together I had 275 in mind so I am quite satisfied. It is not really a torque monster but I never intended it to be. Ed didn't want to push the stock block much more, and my injectors were struggling to make that. I don't think I have been that nervous about anything in a long time. I just knew it was going to blow all to **** on the dyno! Only had one scary thing happen...boost controller dip-switches were not correct on the first high boost run. It spiked to 20 psi immediately. Before Ed could get out of the throttle it made 276 @ 4600 rpm!
Modified by -Trinitron- at 11:16 PM 8/26/2005
Old Aug 26, 2005 | 07:08 PM
Dr. D-Series's Avatar
Good work.
Good #'s.
Must be fun.
Good luck.
Old Aug 26, 2005 | 07:36 PM
s2kdre's Avatar
Default Re: (Dr. D-Series)
high numbers.
Old Aug 26, 2005 | 07:48 PM
Dunc's Avatar
BCICAN
Default Re: Tuned Finally!! (-Trinitron-)
nice man. I would have been like fuuuuuckkkk 299?!!!?! try breathing on the intake filter to get a cool charge Then you'll be in 300 club
Old Aug 26, 2005 | 08:52 PM
1point5CRX's Avatar
Default Re: Tuned Finally!! (Dunc)
yeah that 1hp is gonna make you lose sleep. it would to me lol
Old Aug 27, 2005 | 09:07 AM
GhostR1da02's Avatar
Old Aug 27, 2005 | 12:53 PM
mhx's Avatar
mhx
got any pics of your setup?
Old Aug 27, 2005 | 02:52 PM
T.J.'s Avatar
Glad to see you got it running good. You need to take me for a ride soon Trinton
Old Aug 28, 2005 | 05:38 PM
Yeah, I was still happy. If it would have been 10 degrees cooler I would have hit 300+. I am going to change to a 3-bar map on 12-14 lbs and try again. But for now...it is a lot of fun to drive.
Old Aug 28, 2005 | 05:42 PM
93turbo16's Avatar
some good numbers on that boost I must say. That is a big HP jump for 4 psi. Starting to get the turbo closer to efficiency.
Old Aug 28, 2005 | 05:48 PM
wtfman2's Avatar
Default Re: (93turbo16)
Nice job.
Manny86
Sep 19, 2007 06:21 PM
integra3586
Dec 13, 2006 09:06 AM
slammed_coupe
Aug 28, 2006 09:31 AM
Yani
Mar 30, 2006 07:56 PM
ITR981002
Mar 10, 2003 08:36 AM
