trying to finish up this project
Old May 9, 2013 | 11:31 PM
roll8221's Avatar
Default trying to finish up this project
This is my setup this far below... thinking I need 3" intercooler piping but cant seem to find a kit anywhere online. I also have not picked out a wastegate yet. I know tial is a good one but looking for something possibly a little less expensive. Any help? All is appreciated. you guys got me this far...
1996 civic DX coupe
2001 b18c1
-Hasport Mounts
-CP Pistons 81.5
-Manley rods
-ACL bearings
-ARP main and head studs
-Supertech valves, springs, retainers, guides, seals
-Supertech block gaurd
-Clutchmasters 6 puck stage 4
-Aeromotive 340 fuel pump
-AEM fuel rail
-AEM fuel pressure regulator
-ID725 injectors
-Skunk 2 pro intake mani
-Skunk 2 70mm alpha throttle body
-Precision6262 Turbo
-Mishimoto G Line 24.5" x 11.75" x 3" intercooler
-HKS BOV
-OEM gaskets, oil pump, water pump
-Moroso 5.5 qt oil pan
Old May 10, 2013 | 02:36 AM
rich7777's Avatar
Default Re: trying to finish up this project
Read through the FAQs please https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Ditch that block gaurd as well...
Old May 10, 2013 | 06:20 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
ID725 injectors and you think you need 3" piping? Without knowing your power goals (but looking at injector size alone tells me they aren't very high) all I can say is your list stinks.
Old May 10, 2013 | 06:30 AM
kyden's Avatar
I don't see sleeves on the list anywhere, so how are you going to put 84.5mm pistons in a gsr block?
Old May 10, 2013 | 12:06 PM
roll8221's Avatar
my bad... I meant 81.5... prolly just got done reading another post... I intentionally left as much in the block when I had it machined because I didn't want to sleeve it... power goal is between 400-450... and yes 725 injectors... recommended by my tuner for my power goal... P.S. too late on the block guard, its already in there.. Engine is complete, just doing turbo setup now...
Old May 10, 2013 | 12:11 PM
roll8221's Avatar
hey rich7777, I went to the link you provided but did not find anything on piping size, do you have a direct link? some of the links I did try were dead as well.
Old May 10, 2013 | 01:09 PM
rich7777's Avatar
I was trying to get at the whole idea of how to select your intercooler piping size..
You don't need 3" though. Just use silicone reducers off the intercooler (3" > 2.5"). You'll be making life easier for yourself this way, instead of harder...
Old May 10, 2013 | 09:54 PM
roll8221's Avatar
thanks rich7777, I appreciate it. I actually called my tuner to ask him plus I looked up some other sites as well and they all said the same thing so 2.5 is what im going for... thanks again...
Old May 10, 2013 | 10:46 PM
NZXTInerTia's Avatar
http://www.ebay.com/itm/3-TOP-Aluminum-Turbo-Intercooler-Piping-Kit-U-Pipe-/150823697933?pt=Motors_Car_Truck_Parts_Accessories&hash=item231dcafe0d&vxp=mtr
That was hard.
Old May 10, 2013 | 11:07 PM
rich7777's Avatar
Originally Posted by NZXTInerTia
Lol, you know there's only a 1/10 chance that crap will fit ?
Roll8221 - Here's where I purchased a lot of my turbo stuff from. http://www.go-autoworks-store.com/
Have a look around their site. You may find a few bits what you need...
Old May 10, 2013 | 11:20 PM
stowne78's Avatar
I just bought U-bends and straights and made my own piping...not that hard. After I cut it and marked it up then took it to the shop to weld. Fits great.
Old May 10, 2013 | 11:22 PM
stowne78's Avatar
And yes you will never need more than 2.5" with your setup.
Old May 13, 2013 | 11:56 AM
roll8221's Avatar
thanks again rich. Found a kit, just waiting on an email back...
Old May 13, 2013 | 11:59 AM
roll8221's Avatar
we already hit our douchebag limit of one on this post chief... I give you props on verifying for everyone it in only three words though...
Old May 13, 2013 | 12:10 PM
rich7777's Avatar
No problem. Good luck
roll8221
Nov 4, 2015 07:11 PM
SergieL
Apr 23, 2015 03:55 PM
roll8221
Apr 11, 2015 06:24 AM
Hondarookie93
Oct 30, 2010 04:58 PM
itsjdm
Nov 11, 2008 10:39 AM
