Troubleshooting: Is the following a Blow off valve limitation or other issue?
Hey. My blow off cant handle over 2000rpm pressure in intake. What's can i do to prevent it? Civic VI D15Z6 Eaton M65
Re: Troubleshooting: Is the following a Blow off valve limitation or other issue?
Being a supercharged application, those little chargers can make boost really quick. You need to remove the bypass valve and test it to ensure that it is working properly.
This can be done easily with a vacuum/pressure tester. If while bench testing, it cannot hold pressure, you need to replace the valve or repair whats damaged.
civic_dork
08-21-2005 10:50 AM
