Trouble on a B16A1 turbo engine
Old Nov 17, 2003 | 01:09 PM
crxman_fr's Avatar
Default Trouble on a B16A1 turbo engine
Hello guyz,
I'm from France and I own a 91' honda CRX VTEC type EE8.
I've finished to install my brand new turbo kit two days ago and I've got some technical problems with it :
When I'm running in the VTEC, the engine make some strange noise like Brrrr Brrr Brrr ???
If I switch of the vtec with my VAFC I can easily drive ... no noise, nothing special.
Maybe other guy had the same trouble as me please help !!!
Here is my setup :
Full turbo kit from Turbo Specialities (fit old integra with B17A engine)
Turbo : Garett T25BB,
2 more injectors from Valeo,
Aditional Injectior control Unit Turbo Specialities,
Boost controller Greedy Profec E01,
Apexi VAFC (flat map),
Low compression SRP pistons,
Scat hi beam rod,
Ferrea valve,
Stock ECU,
Stock cam gear.
I use the setup incude in the turbo kit for the Aditional Injectior control Unit, 7 PSI of boost, and 13° timing advance.
Please help me
Old Nov 17, 2003 | 02:57 PM
Bailhatch's Avatar
Default Re: Trouble on a B16A1 turbo engine (crxman_fr)
describe the sound a little better if you can. Might be detonation
Old Nov 17, 2003 | 03:39 PM
crxman_fr's Avatar
Default Re: Trouble on a B16A1 turbo engine (mattssi)
First I was thinking of about a detonation but my engine only make that noise when the VTEC goes on, and I only got 7 PSI of boost and I ad a lot of fuel to be sure ...
Old Nov 17, 2003 | 06:21 PM
Bailhatch's Avatar
vtec demands more fuel so that might be why it could be leaning out, if it is. How fast is the Brrr Brrr Brrrr sound?
Old Nov 18, 2003 | 01:59 PM
crxman_fr's Avatar
Default Re: Trouble on a B16A1 turbo engine (Bailhatch)
Today a guy told be that has I have CTR cams in my engine I have to ad some adjustable cam gear and tune my engine to delete my problem when the vtec is runing ...
What do you think about that ?
zenon8890
Aug 2, 2007 11:29 AM
drew102
Jul 24, 2004 10:24 AM
quickasshatch
Apr 19, 2004 07:30 PM
NyteTyme2002
Oct 5, 2002 06:05 PM
cyberx
May 20, 2002 10:06 AM
