Turbo in on a v-tec engine
Old Oct 2, 2002 | 04:34 PM
NyteTyme2002's Avatar
Default Turbo in on a v-tec engine
Is there anything wrong with putting a turbo kit on a v-tec engine such as the type R ????
Old Oct 2, 2002 | 04:58 PM
Audi A4's Avatar
Default Re: Turbo in on a v-tec engine (NyteTyme2002)
yeah high compression is ur enemy.
Old Oct 2, 2002 | 05:00 PM
letsride's Avatar
Default Re: Turbo in on a v-tec engine (DRAG lll INTEGRA)
One word ...DETONATION!!
[Modified by letsride, 9:01 PM 10/2/2002]
Old Oct 2, 2002 | 05:13 PM
Audi A4's Avatar
Default Re: Turbo in on a v-tec engine (letsride)
also u dont seem to know too much about turbo, so i advise u not to **** with it, TYPE R motors arent cheap.
Old Oct 2, 2002 | 05:21 PM
ImportReview
Guest
Posts: n/a
Not really, it should take like 6 PSi no problem.
But 8 PSi or something might cause you to detonate....but if you have like 93-94 octane, your living large.
Jeff
Dee's Avatar
Dee
Do a serach! This topic is been beaten to death already! Turbo isn't bad for VTEC
Old Oct 2, 2002 | 07:57 PM
TrueZen's Avatar
Talk to the FI forum
Old Oct 3, 2002 | 06:18 PM
gsrhunny's Avatar
Like Drag said....Type R engine is high compression.....high compression and turbo don't mix unless you want to blow it. You need to lower the compression.
Old Oct 3, 2002 | 08:15 PM
JMX's Avatar
JMX
Default Re: Turbo in on a v-tec engine (gsrhunny)
i have seen one turbo on an R, it ran maybe 4 tenths faster than a stock R
the R tranny dosent help either
Old Oct 3, 2002 | 08:23 PM
integRated109's Avatar
Default Re: Turbo in on a v-tec engine (jmx2323)
i bolted on a drag turbo kit and pushed 270 to the wheels@8psi. turbo type R is a beautifull thing, go ask in the FI forum.
just be carefull of the evil dial on the profec.....it will destroy you.
Old Oct 3, 2002 | 09:05 PM
Ado's Avatar
Ado
Hey
Yes high compression isn't a very good thing when your turboing a car, but it also has to do with the extra lobe on the vtec cam. Most Drag cars that use turbos just use the head for the flow reasons, they don't use the Vtec feature.
Old Oct 3, 2002 | 10:22 PM
SIK IN DA HED's Avatar
New User
Default Re: Turbo in on a v-tec engine (Ado)
nothing wrong with turbo on a vtec motor. sheesh... do a search.
compression is high... but it isnt necessarily a bad thing. i wouldnt boost no more than 7psi on a b18c5. dont forget... tuning is the ket, too... tune it right and it should hold up EASY.
Old Oct 4, 2002 | 08:54 PM
grngsr01's Avatar
Default Re: Turbo in on a v-tec engine (dlplayboy)
I read this in the FI forum...
One main concern in power production with forced induction is effective compression. Effective compression is the sum of the motors static compression, plus the additional compression added by the forced induction tool. A B18C1 (also B16A) motor will have a higher effective compression than a B18B motor will, on the same boost...therefore, pound for pound, it will make more power.
The next argument that people usually bring up is that a higher compression is bad for turbocharging. Well, if you understand the concept of effective compression, then you should understand that this statement is entirely incorrect. A higher compression engine makes more power in NA form. So, why do you turbo guys think that a lower compression turbo motor makes more power? Does that make any sense when you really think about it? A turbocharger is a power adder? So why deplete power that was there to begin with? The answer I usually get to that is "So I can run more boost!" Well, sorry to rain on your parade, but more boost does not always equal more power. Check out this mathematical example of effective compression:
A motor with a 10.0:1 static CR boosting 10psi
10psi/14.7psi = .68
.68 + 1 = 1.68
1.68 x 10 = 16.8 effective CR
A motor with an 8.5:1 static CR boosting 10psi
10psi/14.7psi = .68
.68 + 1 = 1.68
1.68 x 8.5 = 14.28 effective CR
Now tell me who is going to make more power? The higher CR motor, or the lower CR motor?
So, maybe add more boost to the lower CR motor, right? Wrong...
A motor with an 8.5:1 static CR boosting 13psi
13psi/14.7psi = .88
.88 + 1 = 1.88
1.88 x 8.5 = 15.98 effective CR
Now you see, even adding 3psi of boost, still does not equal the effective CR of the higher compression, lower boost motor.
Effective compression is not the only advantage of the B16A/B18C1 either. The B16A/B18C1 has a stronger, better flowing cylinder head. It can rev much higher, making it that much more effective, and it flows great to handle all of the extra volume. The block has oil squirters to help support the bottom end assembly at high RPM. It takes more than a valvetrain upgrade to make a B18B safe at 8k. The higher compression also aids in spooling the turbo faster too.
Both motors have similar tolerances though. Both motors pretty much top out at around 350-400hp on stock motors, very well tuned. The B18C1 will make it far more efficiently for you though. It takes less boost to do so, it has more safeguards...and the bottom line on any Honda motor is tuning. If it is well tuned, you will be set. That goes for both motors. YOU ARE A FOOL if you think for one second that just because your B18B has a lower compression, you can substitute that for proper tuning.
A lot of people like to lower their motors compression when they build their motor. I used to think it was a good idea before I understood about tuning, and the positive aspects of compression. In the mathematical representation below, I will show you how a low compression motor must boost more to equal the output of a higher compression, lower boost motor:
Motor: stock B16A2 boosting 7psi.
Static Compression Ratio: 10.4:1
((boost psi / 14.7) + 1) x motor compression = effective compression
Stock motor (10.4:1 CR) on 7psi:
7psi/14.7psi = .47
.47 + 1 = 1.47
1.47 x 10.4 = 15.288 effective CR
Built motor (9.0:1 CR) on 7psi:
7psi/14.7psi = .47
.47 + 1 = 1.47
1.47 x 9 = 13.23 effective CR
You will lose 2.058 points from your effective compression ratio, this translates to a significant power loss.
In order to gain back that power, you have to do this:
Built motor (9.0:1 CR) on 10.5psi:
10.5psi/14.7psi = .71
.71 + 1 = 1.71
1.71 x 9 = 15.39 effective CR
Add 3.5psi to what you were boosting before, and you should be able to make around the same power as before, granted you haven't done any other kinds of modifications port/polish, cams, etc...
As you can see, considering all things stay equal (bore/stroke/cylinder head/etc...), you must add 3.5psi to make the motors perform similarly. You just spent about $2,500 to build your bottom end, and make your car slow.
By now we all should understand the positive aspects of compression, and how when teamed with the faster spoolng turbo, more efficient output, better flowing B-series VTEC cylinder heads, better low end spool time, stock oil squirters, higher redline, etc...you should see that turbocharging B-series VTEC motors is clearly not dangerous, and highly adviseable. I love a good turbo B16A.
is this making any sens????
Old Oct 5, 2002 | 05:56 PM
TREVER's Avatar
Default Re: Turbo in on a v-tec engine (grngsr01)
well said
Old Oct 5, 2002 | 06:05 PM
piatl7il77's Avatar
Default Re: Turbo in on a v-tec engine (TrueZen)
dinku27
Sep 12, 2005 05:28 AM
FastHonda55
Mar 3, 2003 01:57 PM
iWannaGoFast
Jan 16, 2003 06:56 PM
rocket_R
Jun 4, 2002 10:27 AM
MUGENTYPER
Feb 6, 2002 12:04 AM
