Transmission selection on 550+whp
Old Jan 31, 2003 | 11:44 AM
K20  EG's Avatar
Default Transmission selection on 550+whp
ok ..i have been using an ls trans with an lsd ..3rd and 4th gears are longgggg..it feals great..but it seems as if the carsetup boosts slower in those gears..i have recently aquired a brand brand new gsr transmission ..and a quaife lsd...what are the fast guys running ..ls or gsr ..then comes down to the question of tire sizing (slicks) i would like to run a gsr trans ..since my ls is down for the count (bad hub rings) and just up the tire size on the track ..
this situation brings question to my mind only because when i first started runnin turbo with 350+whp..i had a b-16 trans ...it seemed really nice...felt good ..and the turbo spooled quicker than a hooker could suck a golfball through a garden hose
[Modified by RevhardEG, 12:51 PM 1/31/2003]
Old Jan 31, 2003 | 12:08 PM
jinxproof99's Avatar
New User
Default Re: Transmission selection on 550+whp (RevhardEG)
550 to the wheels with a 9500 or better rev limit and 25" slicks.......use the b16.
Old Jan 31, 2003 | 12:15 PM
1FSTCPE's Avatar
I would agree with jinx b16 trans
Old Jan 31, 2003 | 01:38 PM
DLB1994's Avatar
Default Re: Transmission selection on 550+whp (1FSTCPE)
with out reving you motor like a mad man aka jinx and and running on short slicks and street tires get a gsr tranny
if you go with a b16 tranny you will be going to 5th on a 8000-8500 revlimter on 22-24inch slicks
and on some 205-50-15 street tire you will be well in 5th by the time you get thru the 1/4
my vote gsr tranny for 550whp
Old Jan 31, 2003 | 03:58 PM
K20  EG's Avatar
Default Re: Transmission selection on 550+whp (DLB1994)
im fellin this ...it doesnt hurt to try it ...
i was thinking ...since the gears are a lil shorter in a gsr trans than an ls ...i shouldnt fall out of boost ..between gears ...that was kinda of happening b4 .but not to the degree were i was losing tenths..
How does everyone feel about the Dual disk clutch from clutchmasters
Old Jan 31, 2003 | 05:07 PM
tony1's Avatar
Default Re: Transmission selection on 550+whp (jinxproof99)
You're all wrong, longer gears are better for turbo...
Old Jan 31, 2003 | 08:49 PM
New User
Default Re: Transmission selection on 550+whp (tony1)
...............You're all wrong, longer gears are better for turbo...
hahahahaha
Old Jan 31, 2003 | 08:50 PM
New User
...........How does everyone feel about the Dual disk clutch from clutchmasters
the twin disc is an awsome clutch. holds over 600 to the wheels.
Old Feb 1, 2003 | 10:33 AM
K20  EG's Avatar
ya ..i cant wait to get my new setup going ..i should be trailoring it to the dyno here in the next week or so.
As far as the Trans mission selection ...im gonna shoot in the middle and try out the Gsr ...if im not satisfied ...i can always go back to my Ls ...for some reason i have a strong feeling that the Gsr trans with 26 inch slicks ..is gonna be the magic number
Old Feb 6, 2003 | 05:50 PM
jwaked's Avatar
I agree with Tony1. A bit long 3rd and 4th are good for turbos.
Jay
Old Feb 6, 2003 | 05:55 PM
Quick 200k Mile Motor's Avatar
Default Re: Transmission selection on 550+whp (jwaked)
doh! people needa learn
Old Feb 6, 2003 | 06:20 PM
trbob16a's Avatar
Default Re: Transmission selection on 550+whp (Quick 200k Mile Motor)
b16 tranny here
Old Feb 6, 2003 | 08:15 PM
New User
Jay
i think he was joking.
Old Feb 6, 2003 | 08:17 PM
tony1's Avatar
I thought the was enough indication of sarcasm, but i guess not
Old Feb 6, 2003 | 08:28 PM
Flamenco-T's Avatar
tony never joke around
Old Feb 6, 2003 | 09:08 PM
miller's Avatar
Default Re: Transmission selection on 550+whp (Flamenco-T)
as far as the clutch master twin disk, i have seen it slip with just a little more then 600 to the wheels. i would recommend tilton for anything above 600.
Old Feb 6, 2003 | 10:46 PM
Quiklude's Avatar
Default Re: Transmission selection on 550+whp (vtecdoc)
i have never really understood this get a longer gear because you will be in boost longer, i dont believe that is true. the reason one would want to go to longer gears would be because of traction problems.
Old Feb 7, 2003 | 12:15 AM
BudaKai's Avatar
Default Re: Transmission selection on 550+whp (Quiklude)
Yeah then you have to off set it with smaller wheels. No traction with smaller wheels unless they are very wide. Then you can't turn as well. 12-point turns instead of a U-turn aren't fun.
Old Feb 7, 2003 | 12:59 AM
simple4012's Avatar
New User
Default Re: Transmission selection on 550+whp (tzsir)
b16 tranny would be good i think also.
has anyone here had any experiences with and 4.78 FD in turbo cars? I am going to try this setup with mine.
gsr tranny
quaife lsd
si 3 and 4 gears
jdm itr FD
alreayd have it now so im gonna throw it on to see how the boost likes it. If need be ill take out the FD and re-install the stock 4.40 fd. Opinions welcome please
Old Feb 7, 2003 | 07:22 AM
Boostfed's Avatar
New User
Damnit Tony now you tell me, I just went out and made custom FD of 2.30 FD thought finishing the 1/4 in 2nd gear was good for TURBO.
Rev2 9K
Transmission & Drivetrain
14
Oct 26, 2012 09:34 AM
MR.johnson
Jan 4, 2012 09:00 PM
94lsvturbo
Jul 27, 2010 01:48 PM
poorhonda
11
May 9, 2008 04:28 PM
Atheist
Dec 15, 2004 07:54 PM
