transmission decisions. help please
Old Nov 27, 2006 | 07:14 AM
slambedcivic's Avatar
Default transmission decisions. help please
I just sold my GSR trans for a REALLY good price. So I am in the market for another transmission. Im running a straight up LS Turbo. Its mildly built.... rods, pistons. headwork. ya know.... Im looking for 400 whp. Ill be on the street for the most part but at the track on 22" slicks. should i stick with the gsr trans or should i go with a LS trans for the longer gears and highway milage?
Old Nov 27, 2006 | 07:17 AM
Schister66's Avatar
Man U FTW
i think it really depends on your use for the car.....if you're going to use it at the track a lot, then the GSR tranny would be a better buy. If you're going to use it as a DD, then the LS is probably better since you're not going to be running around at 4k all the time....
---personally i think the LS might be a better choice
Old Nov 27, 2006 | 07:19 AM
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">i think it really depends on your use for the car.....if you're going to use it at the track a lot, then the GSR tranny would be a better buy. If you're going to use it as a DD, then the LS is probably better since you're not going to be running around at 4k all the time....
---personally i think the LS might be a better choice</TD></TR></TABLE>
i want it to be productive in both aspects. maybe i should do a gsr trans with a LS 5th gear? the problem is. LS transmissions are like 400 bucks and GSR transmissions are like 6-700.
Old Nov 27, 2006 | 07:22 AM
Schister66's Avatar
Man U FTW
i'm no tranny expert, but i have heard of people using the LS final drive in a GSR or ITR tranny.....someone else has to be able to help....
Old Nov 27, 2006 | 07:30 AM
thank you very much. up for other opinions
Old Nov 27, 2006 | 07:31 AM
Topdawgg's Avatar
id run the LS... its got LONG gears for the street, and long at the track... on 22inch slicks i was makin good trap speeds and stayin out of 5th..
Old Nov 27, 2006 | 07:35 AM
Default Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">id run the LS... its got LONG gears for the street, and long at the track... on 22inch slicks i was makin good trap speeds and stayin out of 5th..</TD></TR></TABLE>
thats honestly what i was looking for. i wanna stay out of 5th. i dont care about radials on the track. if i have to go to 5th im moving to 24.5s. i guess ill be looking for a LS trans thanks!
Old Nov 27, 2006 | 10:20 AM
Default Re: transmission decisions. help please (slambedcivic)
TTT
Old Nov 27, 2006 | 11:07 AM
FATBOYeg6's Avatar
i would go with the ls tranny. you said it was a straight ls, because the ls tranny is geared for the ls torque curve.
my .02
Old Nov 27, 2006 | 11:10 AM
Muckman's Avatar
Moderator in Chief
I love the GSR tranny. Its the middle ground between LS and ITR/B16 gears. The only downside is the 5th gear. Id prefer the longer LS 5th too.
Old Nov 27, 2006 | 01:16 PM
Default Re: transmission decisions. help please (Muckman)
i dont wanna shift to 5th on the track and i think that with 400 whp i should be okay with the LS trans.
Old Nov 27, 2006 | 09:41 PM
Muckman's Avatar
Moderator in Chief
well I wouldnt expect you to be shifting into any 5th gear at the track unless your trapping over 120mph!
Old Nov 28, 2006 | 06:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">well I wouldnt expect you to be shifting into any 5th gear at the track unless your trapping over 120mph! </TD></TR></TABLE>
with a stock rev limit of 7200, usually shifting around 7k, i was shifting into 5th with my GSR with 22's. altho it was right AT the line. i had to do it. ive beefed up the valve train a bit so i might to to 7800 with this setup. well see
Silvertc
Oct 9, 2009 07:19 PM
Got Snail 2
Jun 30, 2007 09:38 AM
btole
Jun 4, 2003 09:23 AM
turbospool
Apr 30, 2003 06:19 PM
AcuraJ2k
Sep 13, 2001 09:34 PM
