trail of white smoke = ???
if im running rich it should be black smoke right?
if im burning oil it will smell really bad and its blue smoke right?
if its greyish smoke and odorless its coolant burning right?
at idle... i noticed smoke coming from under my hood. im not overheating though. under hard acceleration on the freeway theres a big trail behind me... the cars actually slow down so they can see.
Could it be the seals in the turbo?
[Modified by TheFLY, 7:22 PM 5/29/2002]
no overheating at all. my temp gauge never reaches halfway. radiator fluid is the same level as its been for the last few months.
so... what could it be? my idle seems fine so im really clueless.
edit: erm, while removing the pipe w/ the filter attached to it, i saw a tiny puddle of oil where the silicone and compressor meet. if the other side was leaking... wouldnt it be burned out the exhaust?
[Modified by sushibug, 1:34 AM 5/30/2002]
i checked the compressor side of the turbo. it spins nicely... will keep spinning when i let it go. it also doesnt have any shaft play still.
Is the smoke occuring during acceleration, or after?
I had a problem where my head lifted a bit off the gasket, and I would only get clouds of white smoke after acceleration, completly off the gas pedal. It would occur during the transition from boost to vacuum, coolant would get sucked into the cylinders and smoke like mad!
A retorque of my copper gasket fixed it, although it did score the cylinder walls a bit...
Rebuild the turbo - oil in the piping is not good.
Do you have any oil gauges? If I were you, I would be watching your oil pressure/levels and coolant levels.
My guess is that you are just burning the oil in your turbo. Sounds like what happened to me - I had to get the O-rings in the turbo redone.
Dave
Dave
i know a few 3000gt vr4s that have been spitting 4x more oil into their intake piping them me. they've been running on the same turbo for quite some time now. also, if i was burning oil why cant i smell it?
either way my coolant should be milky right? its the same level and its the same nasty azz green color.
you are in denial, do your self a favor and pull the motor apart. white smoke most likely it's a burnt piston. perform a leak down test is the best way to eliminate uncertainty..........
jdmek2277
10
Dec 13, 2007 10:54 AM
EtherEG93
Sep 17, 2005 08:18 PM
time for a rebuild... blown head gasket?? but im thinking blown piston and block.but i could be way off.
