traction with turbo
Old May 12, 2003 | 02:22 AM
slowassgsxr750's Avatar
Default traction with turbo
how do you get traction on street tires with boost?i have 309 whp,right when i boost nothing but wheel spin,1-2-3 gear,cant do better then a 15.0,also getting 2.8-3 60 ft.
Old May 12, 2003 | 02:33 AM
MiraiZ's Avatar
Default Re: traction with turbo (singleslamrex)
fatter tires, or lower tire pressure...
Old May 12, 2003 | 06:20 AM
ludesleep's Avatar
Default Re: traction with turbo (MiraiZ)
lsd is always nice
Old May 12, 2003 | 06:46 AM
Gravy's Avatar
Default Re: traction with turbo (ludesleep)
play with the throttle. you can still move while spinning.
Old May 12, 2003 | 06:56 AM
@irborne's Avatar
16" rims and 235 or wider tires
Old May 12, 2003 | 07:03 AM
Joseph Davis's Avatar
Default Re: traction with turbo (@irborne)
Turn up the boost. It worked for Speed PHreak... the line running to his MBC blew off, boost spiked to 24 psi, he hit a 12.8@120 with a ~2.8 60' time.
OK, I know that really wasn't a constructive suggestion
Old May 12, 2003 | 07:48 AM
PM-Performance's Avatar
Default Re: traction with turbo (J. Davis)
hahaha , whats traction ?
Old May 12, 2003 | 07:55 AM
swlabhot's Avatar
Racelogic TCS....
Old May 12, 2003 | 07:57 AM
BoostedsiR's Avatar
Default Re: traction with turbo (itr206)
I would go to your local tire warhouse in town and look for a brand of tires called Warriors. they are ugly and they only for 13's or 14's but they ******* grip and they are 29 or 30 bucks it is worth it and you drop about 5 psi out of the tires you are good. I dont like going the cheap way but you will be suprised how these things grip
Old May 12, 2003 | 07:59 AM
BoostedsiR's Avatar
Default Re: traction with turbo (BoostedsiR)
bfg drag radials Ive heard nothing but good things from those
Old May 12, 2003 | 08:00 AM
Vu's Avatar
Vu
Get a better boost control. Something that let's you set your boost according to speed, rpm, or gear.
Old May 12, 2003 | 08:44 AM
ski_rebel_3's Avatar
Default Re: traction with turbo (Vu)
You might also want to try Energy Suspension motor mount inserts and traction bars.
Old May 12, 2003 | 08:53 AM
Mr Hammond's Avatar
a/k/a Jomo
How are you launching? Are you just reving it and droping it and mashing the throttle and not letting off? Judgeing by 60' appears that way. Feathering the clutch and throttle work best.
Old May 12, 2003 | 08:57 AM
Default Re: traction with turbo (ski_rebel_3)
Ski_rebel_3 is on the right track, if you stop and think about it.
You're applying way above stock power levels to stock suspension with probably less than perfect condition components. I know I can actually pull off a good launch and 1-2 shift with a little feathering of the gas pedal, with next to no wheel spin. About four months back I could bark 4th @ 80 mph on Azenis my suspension was so inadequate. I have an OK setup in a light car, but it's not anywhere near that powerful if everything is correct.
Make sure your car is not dumped or running a lot of camber, as that kills traction. Make sure your car is in perfect alignment. Start looking at shock/spring combos, motor mounts, and traction bars.
FYI, my HASport mounts, now 2 years old, are allowing a lot of engine movement. I've fabbed up the front mount for my engine, and it is a LOT better.
Old May 12, 2003 | 09:02 AM
MaxBoost's Avatar
New User
24.5*8*13" MH Slicks
Quaiffe Differential
ES motor mount inserts
ES suspension bushings
JimFab, Z10, or Comp Eng. Traction Bars
Speed/Gear Sensitive Boost Controller
Lower Tire Pressure
Proper Alignment
Better driving (ease out clutch, feather throttle, etc..)
1000lb Rear Drag Springs
Better shocks
Try all those, if none of them work, then go all-motor. lol.
I could imagine a stock EG (bone stock) with just a 350whp turbo setup under the hood... it would probably run 15's on those stock granite tires, and shitty suspension..then I could imagine it dropping 4 seconds in the quarter mile with just some of the above (non-power adding) mods..
Modified by MaxBoost at 10:13 AM 5/12/2003
Old May 12, 2003 | 09:22 AM
Default Re: traction with turbo (MaxBoost)
my camber is perfect,my suspension is pretty new 2001 type r,i baby the throttle and it still spins out,on my old car with the same set-up,the wheels spun but i still was taking off,on this car it feels right when i hit boost the car just doesnt move
Old May 12, 2003 | 09:26 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost &raquo;</TD></TR><TR><TD CLASS="quote">24.5*8*13" MH Slicks
Lower Tire Pressure
Proper Alignment
Better shocks
Modified by MaxBoost at 10:13 AM 5/12/2003</TD></TR></TABLE>
He said it all, listen to him. I recommend the avc-r boost controller personally, then set it for lower boost for your lower gears.
b18c195
Feb 13, 2005 06:06 PM
CaptainMorgan
Mar 7, 2004 11:13 PM
crazyitr
Aug 3, 2003 11:19 PM
C-Murdock
May 10, 2003 07:35 PM
raene
Oct 2, 2002 05:40 AM
