Traction Help
Old Jan 5, 2006 | 09:39 AM
budget's Avatar
Default Traction Help
I know this is no new problem, just want to get an idea from your solutions.
When getting drag radials-
-how long will they last if they are used as daily drivers?
-i know you can "heat" them up at the track. but does "heating" them up on the street does it have the same effect?
-will i break anything luanching hard with them?
Old Jan 5, 2006 | 09:45 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
BWAHAAAAAHAHAHAHHAHA!!!!!
that is all.
seriously, don't ever use drag radials on the street. you will only have traction when the road conditions are perfect. if you get caught in the rain with drag radials on the street, you might as well call 911 to report an accident ahead of time.
Old Jan 5, 2006 | 03:20 PM
D@nnY's Avatar
they wheel hop alot mroe then slicks because of the harder sidewall..i made 7 passes on slicks and oem axles and didnt break and 1 pass on bfgs and it wheel hopped and broke an axle first pass
you can drive on them in the street they will just wear out fast theya re street legal tires.....
Old Jan 5, 2006 | 03:37 PM
Tippyman's Avatar
Default Re: (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY &raquo;</TD></TR><TR><TD CLASS="quote">you can drive on them in the street they will just wear out fast theya re street legal tires.....</TD></TR></TABLE>
may be legal, but not smart. i've heard they wear out on about 10,000 miles to.
Old Jan 5, 2006 | 04:02 PM
EF8 D-UNIT's Avatar
Default Re: (Tippyman98)
oh!.. so they wear out as fast as piece of crap Toyo T1-S's—minus the traction!
Those tires SUCK
-Rob
Old Jan 5, 2006 | 04:40 PM
mike1114's Avatar
Default Re: (EF8 D-UNIT)
For good traction the tried and true methods work.
Good suspension
Good clutch
LSD
Traction bars
The traction bars and good susp help a lot on wheel hop. I daily drive BFG's and race them every weekend. I have about 400whp, and I have STOCK axles, haven't broken one......yet........
The BFG's last me about 4, maybe 5 months tops.
Preloading the clutch when your about to launch is the key to not breaking stuff.
If you wanna go all out, there are also limit straps (search fools) I've heard they can be daily driven but aren't too happy about it. I do think they can be loosened for daily driving then tightened down for race time but I've had no experience with them.
Old Jan 5, 2006 | 04:50 PM
budget's Avatar
Default Re: Traction Help (suxway)
Old Jan 5, 2006 | 11:34 PM
D@nnY's Avatar
preloading the clutch may also screw up the clutch pressure plate and flywheel...the bigger the sidewall of the tire the better off youll be
Old Jan 6, 2006 | 12:49 AM
IGotVTECyo's Avatar
Dont mean to jack this thread, but how does a 225/50/15 sound on a 300-350hp civic hatch? Will traction be an major issue on the track or street?
Old Jan 6, 2006 | 03:37 AM
spoon92hatch's Avatar
Default Re: (IGotVTECyo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IGotVTECyo &raquo;</TD></TR><TR><TD CLASS="quote">Dont mean to jack this thread, but how does a 225/50/15 sound on a 300-350hp civic hatch? Will traction be an major issue on the track or street?</TD></TR></TABLE>
Good go with the BFG G-Force
Old Jan 6, 2006 | 05:41 AM
sp00led's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8 D-UNIT &raquo;</TD></TR><TR><TD CLASS="quote">oh!.. so they wear out as fast as piece of crap Toyo T1-S's—minus the traction!
Those tires SUCK
-Rob</TD></TR></TABLE>
I have never used the T1-S but its replacement the T1R I have road on since earlier this past summer. Still have lots of tread and there ability to hold the road in the turns is amazing. As for traction while drag racing, come on it's FWD of course we are going to have issues with anything besides slicks.
Old Jan 6, 2006 | 06:43 AM
PM-Performance's Avatar
Default Re: (sp00led)
T1's were good tires. I had a few sets of them.
Drag radials dont really perform well for handling IMO. They wear out quick too. If you want a stickier DR type tire go with the Nitto. They wont hook like a BFG, but the wear is less and have stiffer sidewalls.
I still think the Azeni's is an all around awesome tire.
Old Jan 6, 2006 | 07:41 AM
ELSpool's Avatar
I'm curious as to how the Yoko's A035R in a 225 50 15 perform. I know it's an R compound that won't wear as fast a the BFG D/R and still be sticky, but I'm not sure if the hard side wall will hurt straight line performance...?
Old Jan 6, 2006 | 08:47 AM
kameleon23's Avatar
Default Re: (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">I'm curious as to how the Yoko's A035R in a 225 50 15 perform. I know it's an R compound that won't wear as fast a the BFG D/R and still be sticky, but I'm not sure if the hard side wall will hurt straight line performance...?</TD></TR></TABLE>
I had that exact tire on my 340 HP EM1, and i wasnt all that impressed. Handling was awesome, but straight line wasnt much better than some less expensive tires i have used in the past. They wore really fast too IMO
DEL HATCH
22
Oct 4, 2006 08:34 PM
wfocrx
Oct 3, 2006 07:40 PM
8point6
May 5, 2005 05:00 PM
DarkBB4
Nov 22, 2004 11:44 AM
bad93ex
11
Sep 5, 2002 11:25 PM
