TPS sensor question
Old Mar 30, 2004 | 07:49 PM
turboedsi's Avatar
Default TPS sensor question
how do u know when your tps sensor goes bad? I know Cel, but anything else?
I ask this because my car idles funny and around 4k rpms it hesitates.
idles at like 800rpms and then bumps to like 1300rpms. Back and forth, back and forth.
little bit of info on this would be nice. Or what the problem might be.
Thanks, andy
( would an alternator do something like this? ) i say that when im at idle my volt guage goes from 14volts to about 12ish. I think thats when my car bounces around in the rpm range.
Thanks
Old Mar 30, 2004 | 08:01 PM
Nid Styles's Avatar
Default Re: TPS sensor question (turboedsi)
Could be short. or IAT.
Old Mar 30, 2004 | 10:27 PM
TravSi's Avatar
mine did that and it was because I didnt have the right vaccumm signal to my map sensor and it caused the idle to get all screwy...went from 700-1300 back to 700 then up to 1300...very annoying, The reason was because I tried eliminating that stupid charcoal can on my crx and got a vaccumm manifold and ran a line for the map right from it...well it wouldnt work, so finally i put everything back to stock and the car idled fine....but anyway thats what caused my problem similar to yurs....
Check the voltage on yur tps 0v closed .5v open I believe....about the only way i know to check for sure to see if its reading correctly
Old Mar 31, 2004 | 01:55 AM
Lei Siew Long's Avatar
Default Re: TPS sensor question (TravSi)
if i'm not mistaken, it is 0.5 v closed and 4.5 v WOT
Old Mar 31, 2004 | 02:08 AM
pornstarSR's Avatar
Default Re: TPS sensor question (Hatch4urSnatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch4urSnatch &raquo;</TD></TR><TR><TD CLASS="quote">if i'm not mistaken, it is 0.5 v closed and 4.5 v WOT</TD></TR></TABLE>
yep thats it
Old Mar 31, 2004 | 02:38 AM
leed's Avatar
Default Re: TPS sensor question (pornstarSR)
IMHO error on the side of &lt;.5 at closed throttle. Around .48-.49.
The smallest error when setting the TPS can cause part throttle (tip in/out) hiccups. A misadjustment can also show up as a premature fuel cut at around 1800 with minimum throttle, ie ECU thinks throttle is closed and cuts fuel (corrects for an idle problem when there is none)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">how do u know when your tps sensor goes bad? </TD></TR></TABLE>
If it was bad your car would drive like a Gremlin on 2 cyl, unplug it and see what it does.
Old Mar 31, 2004 | 11:03 AM
pornstarSR's Avatar
Default Re: TPS sensor question (leed)
you are right, its supposed to be slightly below .5v like .48 or .49
but aslong as you dont go over .5v at closed it should be fine...
thats the specs that michell and alldata state...
my suggestion about all this... be careful adjusting the TPS....ive adjusted mine to the specs above numerous times, and i still think its causing my problem.... factory set
Old Mar 31, 2004 | 06:01 PM
EKhothatch's Avatar
What would cause your TPS to line up with the bolt holes at .50v and voltage go down instead of up when the throttle is increased. My TPS worked fine but I had to take it off a y8 TB and put it on a z6 TB.
Also, I got it to line up about .57v would that work or would i really need to get it set at .50v and nothing higher?
Old Apr 1, 2004 | 12:52 AM
pornstarSR's Avatar
Default Re: TPS sensor question (inline4hatch)
at .57 the motor could think the throttle is slightly open...thats why we stated that just slightly below is optimal...
try slotting the sensor so it moves..
also there are these metal sleeves in the holes on the sensor, if you take those out you might be able to get you extra .07v...just a suggestion
Old Apr 1, 2004 | 07:37 AM
EKhothatch's Avatar
Good suggestion. I never thought about that. I'll try that and see if it works.
99ek4Dr
10
Mar 2, 2011 06:22 PM
LilCivic04
Aug 1, 2005 11:09 PM
LilCivic04
Jul 31, 2005 09:38 AM
Flamenco-T
Aug 27, 2002 12:23 AM
