TPS?????HELP
Old Mar 4, 2010 | 08:44 AM
jarven93's Avatar
Icon6 TPS?????HELP
well i took my car out last night and took it thew all the gears 10psi everything was running fine, as i was coming to a stop CEL came on, no mechanical problems, so im thinking sensor..... at idle car runs fine but if i take rpms to 1500 car begins to rev fast up and down from 1500 to about 1700rpm then if i give it more throttle to 2000rpms or more it stops but if i take it back down to idle no problems but then back to 1500 it revs crazy again, would this be throttle pos. sensor? if so i looked at on how i was going to replace it, and no bolts, do i have to replace the throttle body its self too?? or is there a way to take it off? any help thanks guys!!! engine is a D16z6 i do know that the throttle body has close to 300k miles
Old Mar 4, 2010 | 08:59 AM
B R Fittings's Avatar
Default Re: TPS?????HELP
To take off the TPS, remove the throttle body from the car. Then take a cutting wheel with a thin blade and make a notch in the metal. Then just take a screw driver and remove it. Honda doesn't sell the TPS by itself, they make you buy a whole new throttle body.
Hope this helps.
Old Mar 4, 2010 | 09:42 AM
jarven93's Avatar
Is there any way to test to see if it is the throttle pos. sensor??
Old Mar 4, 2010 | 01:24 PM
If your running the hondata s300 it shows the tps % when data logging.
Old Mar 4, 2010 | 02:13 PM
93supercoupe's Avatar
whats the CEL for??
That might be a good start
f22vtec1
16
Mar 4, 2011 09:07 PM
sr20detss13
11
Feb 7, 2011 08:03 PM
zuruk
33
Dec 25, 2008 12:06 AM
rcjustin
26
Feb 3, 2006 10:37 AM
OriginalFive
Honda S2000
11
Jul 11, 2005 01:46 AM
