tsi awd
Old Apr 23, 2003 | 12:10 PM
civicrole24's Avatar
Default tsi awd
what should i do. i have an 98 eagle talon tsi awd. it stuters off the start. meaning it takes a while to get going. should i add a bigger turbo to it or do what? or should i sell it?
Old Apr 23, 2003 | 01:05 PM
TeStUdO's Avatar
the turbo on that car is small you should get boost almost right away. something might be wrong with your engine. leakdown and compression check time
Old Apr 24, 2003 | 07:11 AM
okay thanks, but would the boost control help off the line or would that not do anything? thanks for the response.
Old Apr 24, 2003 | 08:29 AM
Killa's Avatar
Default Re: (civicrole24)
the the boot between the TB and the MAF sensor, check for rips that is.
Old Apr 24, 2003 | 11:34 AM
if it has a check compresion and if that isn't the problem then what esle could it be? whats the biggest turbo upgrade i could to to it, or what kind of boost control.
Old Apr 24, 2003 | 12:07 PM
TeStUdO's Avatar
go to dsmtrader.com they have all kinds of turbos and **** fo dsm's there. if comp is good check for rips by the maf like he said
Old Apr 24, 2003 | 12:09 PM
Gravy's Avatar
no a bigger turbo wouldnt help you off the line.
Old Apr 24, 2003 | 12:29 PM
JRSCCivic98's Avatar
Default Re: (GRTechnologies)
What do you mean by stutters... Like it's not wanting to go when you press the gas? Does it feel like you're giving it gas and nothing is happening? If so, it might be your fuel pump acting up. I have a friend with a TSI and his tank was fugged up by the last owner that floded the car. The fuel pump was just pulling crap up in the sock and getting stuffed up.
If the stuttering you're talking about feels like you're bogging it then it's just that. You're bogging it. You can't drive an AWD car like your Civic (guessing from your name) and expect it to just go. If you're racing and want to take off quick rev that thing to 6k and drop it and hold on for dear life. Cuz you'll either hit something or you'll drop your drivetrain on the street.
But really... is it more like a bog or are you flooring it and nothing seems to be happening?
Old Apr 24, 2003 | 06:08 PM
okay what is going on is, when i press of the gas off the start it goes but like its barrly doing anything for a few seconds the it will act normal. but it is just off the start. ?????
Old Apr 24, 2003 | 11:50 PM
.Ash's Avatar
its either fuel (check pump, filter, lines), or its mas related. when theres a mas leak, the car will run like junk, stutter, etc.
Old Apr 25, 2003 | 01:27 AM
FourG63 97GST's Avatar
what kind blow off valve does it have?
and is it vented?
Old Apr 25, 2003 | 06:39 AM
Default Re: (FourG63 97GST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourG63 97GST &raquo;</TD></TR><TR><TD CLASS="quote">what kind blow off valve does it have?
and is it vented?</TD></TR></TABLE>
Yeah, if your bov is vented with a mas sensor setup then it might be that causing the hesitation problem. Plumbing the bov back into your intake like the stock one is will sometimes fix this. You might also want to take out the mas and check to see that there's nothing blocking or stuck to the screen in front of it. If you have a friend with another Talon or Eclipse you can borrow his mas for a few minutes and see if it fixes the problem. If it does, then it's a faulty mas which you need to get replaced. Also, if your car runs like crap all the time you might want to to check and see if the sock on your fuel pump is ok. I think you can get to the pump from under the back seat. Low static fuel pressure will also cause these startup hesitations.
Another point. I don't know if Mitsu ecus work the same way (don't see why not) but when our Hondas run like carp with the stock ecus we usually unplug the ecu for 5 minutes to clear them. Then reconnect and idle the car for 10min and cycle the engine off and back on after that. Then go for a ride to see if things are back to normal. Just a thought...
Old Apr 25, 2003 | 07:08 AM
i have a friend will a 99 Eclipse. will it work on the talon if i switch the mas? or does it matter. thanks for the help.
Old Apr 25, 2003 | 07:35 AM
soundman's Avatar
Go to here and ask some of the guys there. They know DSM better than we do.
http://www.dsmtuners.com/forums/
Old Apr 29, 2003 | 07:03 AM
Thanks that helped. does anyone know were i can find good turbos for a cheap price.
Old Apr 29, 2003 | 07:27 AM
Tinker219's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrole24 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks that helped. does anyone know were i can find good turbos for a cheap price.</TD></TR></TABLE>
cheapturbo.com
allmotor_dm
Jan 24, 2006 06:07 PM
gsr93integra
Aug 15, 2005 07:55 PM
crucial si
May 31, 2003 08:46 PM
Boosted B18C5
Nov 14, 2002 10:40 PM
Boosted B18C5
Nov 13, 2002 07:07 PM
