Topmount users post pics of your return lines
Old Jul 6, 2009 | 12:07 PM
92redhatch's Avatar
Default Topmount users post pics of your return lines
I want to see how to run mine. Thanks
Old Jul 6, 2009 | 12:27 PM
northemt88's Avatar
Default Re: Topmount users post pics of your return lines
Google
Old Jul 6, 2009 | 01:11 PM
92redhatch's Avatar
Thanks buddy. I searched and couldn't find anything.
I'm worried since my return line might be touching my manifold.
Old Jul 6, 2009 | 01:15 PM
jdm inc's Avatar
use heat wrap
Old Jul 6, 2009 | 01:32 PM
92redhatch's Avatar
Thanks I have a heat wrap. Did you use a 45 on the oil pan and a straight fitting on the turbo?
Old Jul 6, 2009 | 05:09 PM
m R g S r's Avatar
touching is deff. a bad idea. make some kind of bracket to pull it away from the manifold. the heat wrap and steel braiding will only do so much, remember it still is a rubber hose under all that.
Old Jul 6, 2009 | 06:11 PM
Blown90hatcH's Avatar
What are you using for hose?
Old Jul 6, 2009 | 06:26 PM
turbojdmhatch's Avatar
what about some -10an steel braid line?
Old Jul 6, 2009 | 06:47 PM
jdm inc's Avatar
yea 45 off the oil pan.
the -10 is still has rubber under the steel so theres a chance it could melt
Old Jul 6, 2009 | 06:51 PM
ls_on_boost's Avatar
here is a pic of mine it wasn't connected to the turbo yet because i had to make it a little shorter.
Old Jul 6, 2009 | 06:52 PM
true... didnt think about it
Old Jul 6, 2009 | 07:14 PM
92redhatch's Avatar
My return is a -10 steel braided hose with a DEI heat wrap. I'm going to try to get it away from the manifold. I'll post pics when I install it. Thanks for all the pics. Is anyone running the return through the two runners on the manifold to the oil pan?
Old Jul 7, 2009 | 04:37 AM
I wouldn't run the return thru the runners. Keep it away from the runners as far as possible. Sometimes though, layout doesn't allow it.
Old Jul 7, 2009 | 05:40 AM
92redhatch's Avatar
Ya I don't have space through the runners.
cleansi
Feb 11, 2012 04:40 AM
pitoracing24
Dec 4, 2007 04:05 PM
blakacintegra
Nov 26, 2006 01:29 PM
m R g S r
Apr 13, 2005 07:16 AM
Mr. Softee
Sep 18, 2003 08:09 PM
