Top vacuum nipple on throttle body.
Old 11-19-2008, 09:37 AM
Marlon88's Avatar
Default Top vacuum nipple on throttle body.
I am installing a full-race turbo kit on a JDM B18C swapped 1991 civic EF.
My question is this, There is a vacuum nipple on top of the throttle body, (originally hooked up to the charcoal canister) Can I use it as vacum source and hook the wastegate to this nipple?
Thanks guys
Old 11-19-2008, 09:39 AM
Mr. Badwrench
boostedcivicsir's Avatar
no it is venturi vac only.
Old 11-19-2008, 12:40 PM
LastGenEK's Avatar
No! The best source is from the comp housing on the turbo, but i run mine off the big nipple on my Skunk 2 mani and it works fine
Old 11-22-2008, 05:08 PM
robx7fcna's Avatar
I agree that the vac for the wastegate should be from a boost only source, meaning there is never vac present.
turbo compressor housings, hot side of the charge pipes are good places to tap a fitting in.
Boricuanology
09-02-2008 09:30 PM
Poey2
02-19-2008 03:09 PM
B16Civic93
03-18-2005 04:33 PM
Quick Reply: Top vacuum nipple on throttle body.
