too rich
Old May 3, 2009 | 02:34 PM
rick_rabies's Avatar
I'm not Rick!
Default too rich
a few days ago after 10 minutes of street tuning my fullbuilt gsr turbo motor..i blew a head gasket. (forgot the dowel pins) i know i know
i put a new gasket in. with dowel pins..
i bled the coolant. gave it alittle oil.
but now the when i turn the car on the wide band says 15.1 ish for only 10 seconds and then quickly lowers to flat 10 (too rich) plugs are black when pulled. nothing else changed..i dont get it. i tapped the gas peddle and it hesitates and feels as though theres too much load like something is gonna break.
timing? ..any suggestions? i serioulsy am about to set this on fire
Old May 3, 2009 | 03:58 PM
Ls_dx's Avatar
Default Re: too rich
Is everything re assembled correctly? piping/couplers..? wb02 ground? what are you running crome?
Old May 3, 2009 | 04:17 PM
I'm not Rick!
all the grounds are good. its crome. my friend half tuned it before we blew the head gasket. but it ran awesome after he adjusted a few things .
Old May 3, 2009 | 04:39 PM
I'm not Rick!
i did take out the charcoal canistor and left the fuel vapor line unplugged and routed the other vacuum hose back into the intake. does every1 do that with a wire tuck though?
Old May 3, 2009 | 05:07 PM
Ls_dx's Avatar
What hose went back to the intake ?
Old May 3, 2009 | 05:36 PM
I'm not Rick!
Name:  evap vacuum.jpg
the bottom hose is going to the bov. the other from the T goes to the top of the throttle body, the 3rd from the T goes to the evap sensor selonoid to the left. the bottom of that selonoid thing goes to the back of the IM. is this wrong? should i leave the TB off?
Old May 3, 2009 | 05:40 PM
I'm not Rick!
to answer your qeustion i think its the top that goes into the throttle body
Old May 4, 2009 | 06:51 AM
I'm not Rick!
bump
Old May 4, 2009 | 08:23 AM
b20beast83's Avatar
check back cam timing
Old May 4, 2009 | 11:18 AM
I'm not Rick!
both cams were lined up with the lines on the side and the crank at tdc
Em1Dustin
33
Mar 7, 2018 06:46 PM
FearDisH22a4
29
Mar 13, 2014 05:10 PM
k3nnex
May 31, 2008 07:19 PM
InTeGrA B18b1
Apr 7, 2005 04:08 PM
b00stedbyFastrax
Aug 5, 2002 08:32 AM
