tire wideness for street...--> canīt decide, Iīm frustrated
What is the best dimension for handling and acceleration for street driving with 350whp on ITR. I will use Volk te37 rims, but before I order rims, I HAVE to know which dimension would be the best for my car.
Should I go for 205/45/16, 205/50/16 or 225/45/16??? 215/45/16 is out of question, not available here.
....or should I go for 215/40/17?
How wide should the rim be? For 205 7inch and for 215 or 225 7.5 or 8inch rims, right
Iīm now using 225/35/17 on 8.5x17inchers and Iīm not happy with the acceleration, too much tourqe steer. The car reacts under acceleration much better with 195/50/15 stock rims.
Please help me out, Iīm frustrated, cause I try to decide on rims and tires a 1/2 year now without any results
New User
Re: tire wideness for street...--> canīt decide, Iīm frustrated (austrian type-R)
You should be much happier on a 7.5" wide rim; the 8.5 will put the tires' grip too far away from the point the suspension was designed for. 7.5" wide rims with 205 width tires can be a spectacular combination - you won't be throwing away any handling or traction.
Re: tire wideness for street...--> canīt decide, Iīm frustrated (dbman96)
I was thinking on putting the 225/45 on 8 inchers. So would it be better on 7.5incher, yes?!
and when using 205ish I should use 6.5inch or 7inch rims, right.
But what is now better, 205, 215 or 225 to get out the best performance?
225 i think is just out of the question
if you can find a 215/40/17 youd be loving life........
but typically all you will find is 205/40/17 this is the standard honda 17" tire set up
but with 350HP, you're gonna want something wider then 205 in my opinion
Re: tire wideness for street...--> canīt decide, Iīm frustrated (NYb16)
why is 225 out of question. My fenders are pulled already. 225/45/16 gets easy under my fenders.
215/40/17 is an standard dimension here in Europe, easy to get. But isīnt the sidewall of the 215/40 a bit to to low. Iīll have more wheel hoop on that than on 225/45/16, right?
Common guys, tell me your experience with best rim/tire combo for high hp applications.
panykus
07-14-2003 12:17 PM
