Boost Controllers!
Old Jul 18, 2005 | 07:41 AM
metal-x's Avatar
Default Boost Controllers!
Ok Im gona start my boosted R project end of the month
there are a few things Im still missing however and one of them is Boost controller
I contacted boosted-hybrid for pricing and hes selling
the GReddy Profec E-01 539.99 shipped
any personal reviews on this unit? price wise seems really expensive
what do you guys look for in a boost controller??
thanks in advance!
Old Jul 18, 2005 | 07:55 AM
tthame1's Avatar
Default Re: Boost Controllers! (metal-x)
I like the Greddy Profec-S, it is very simplistic and it works extremely well.
Old Jul 18, 2005 | 08:01 AM
adseguy's Avatar
What do you want out of your boost controller....let's start with that
If you just want to set it at a certain boost level and that's it then get a Manual boost controller. If you want to swtich easily between low and high boost then an Electronic one is for you. I have mine setup with a button on the shift ****, so when I go through first and second gear I am in low boost (less tire spin) and then in third I can get all 16PSI on the tires without spinning out.
The one you mentioned has a lot of bells and whitsles you may not want or need. A simple MBC or EBC may be better for you, but that boost controller is BAD ***
Old Jul 18, 2005 | 08:08 AM
lucidvtec's Avatar
i use the E-01 from greddy...it's really nice...easy and clean to install....the auto learn funtion takes a little bit to setup...but it has rpm boost control for every 1k .....also dataloggin to a SD card...the screen it comes with works great..even in sunlight...i would get the signal adpt...and the remote switching system...click of the button to high boost to low boost.....that thing has so many functions...i don't even know how to use everything yet and i've had it for a month...good luck and happy boostin
IN VTEC
Feb 13, 2008 07:07 AM
Drkaccrd
Jun 7, 2005 09:28 PM
BodyKits NW
Aug 29, 2003 05:55 PM
Pfieff
Jul 13, 2003 04:58 PM
skilzz
Oct 24, 2002 03:37 AM
