Timing question w/ blue box
Old Aug 9, 2004 | 10:57 PM
AF-b16a1's Avatar
Default Timing question w/ blue box
yes i know the blue box is crap, but until i get the time learn how to use uberdata or money to update to hondata..this is what i am stuck with...now my question was on my boosted sohc (y7)...the idle seems sorta rough and i was wondering what everyone elses timing was at..any suggestions?...i am just trying to get a rough estimate on other peoples set up...thanks for the help i am a turbo noob trying to learn more
also when using the blue box...since it taps into the map sensor...there is no need for a missing link/check valves correct?
Old Aug 9, 2004 | 11:01 PM
SOHC_MShue's Avatar
Default Re: Timing question w/ blue box (AF-b16a1)
i would keep your timing stock at 12 degrees
Old Aug 9, 2004 | 11:08 PM
AF-b16a1's Avatar
Default Re: Timing question w/ blue box (SOHC_MShue)
may i ask why? cause when the kit was dropped...i started the car and the motor was shaking like a ****...adjusted a lil and the shaking went away...
Old Aug 9, 2004 | 11:28 PM
SOHC_MShue's Avatar
what do you mean when the kit dropped? There is no way that your car should be shaking at 12 degrees of timing. Are you sure your timing gun isn't messed up or something and you had it retarded a lot? The blue box is made for you to leave it at stock and then I assume the blue box controlls your ignition tables some...not entirely sure though. The blue box is meant to run on a stock motor though with no tuning really needed so i would just keep it stock.
Old Aug 10, 2004 | 02:21 PM
AF-b16a1's Avatar
ok kool thanks for the information
chad
Aug 15, 2005 03:20 PM
lDanny
Mar 30, 2005 02:14 PM
Blindstuff
May 3, 2004 04:18 PM
-[95cxhatch]-
Feb 9, 2004 04:36 PM
onelowchef
Jan 27, 2004 03:28 PM
