Nitrous Mastermind question
Old Oct 11, 2001 | 10:01 AM
Pinhead's Avatar
New User
Default Nitrous Mastermind question
Ok guys...I'm wondering if you can retard the ignition timing with this unit...and if you can is it a ****? how does it work someone explain this to me please I'm just about to order one and I need to know this...THANKS
Old Oct 11, 2001 | 10:30 AM
rtype11's Avatar
Default Re: Nitrous Mastermind question (typerman1358)
sorry I am only familiar with the Mastermind from Milton Bradley, and I dont think it has a **** for retarding timing just four coloured pie shaped buttons.
Any NOS computer should retard timing for you or let you do it.
[Modified by rtype11, 11:31 AM 10/11/2001]
Old Oct 11, 2001 | 10:34 AM
Big James's Avatar
New User
I am not aware of a product by NOS that retards timing. I know they make computers that adjust the time the nitrous is activated and step controllers that adjust the amount of nitrous used.
If you want to adjust timing, get the MSD unit or the APEX'i Super ITC. The ITC allows you to use different timing adjustments depending on rpm.
Old Oct 11, 2001 | 10:38 AM
rtype11's Avatar
Default Re: Nitrous Mastermind question (Big James)
I clear it Big JIM, I did not mean NOS the company but I think their NOS programmer will let you retard timing on the programming unit. plus they have an individual timing computer for 8cyl. should work on a 4 also, you can advance or retard spark for each cylinder.
Old Oct 11, 2001 | 10:40 AM
Pinhead's Avatar
New User
Default Re: Nitrous Mastermind question (rtype11)
I mean the Jacobs Electronics Nitrous Mastermind...doesn't anyone have this thing!!!???
Old Oct 11, 2001 | 11:30 AM
TEC2's Avatar
New User
well im getting it soon summit sells it for 248.69 part# JAC-383406
you can retrd ur timing up to 15 degrees. only when u spray. allowing u to run stock timing when the nitorus is not in use.
alows u to preset what RPM you want the nitorus to activate, allowing u never to accidently spray at low rpm.
adjustable soft touch rev limiter. also at 500 rpm beofre u hit the rev limiter the nitorus shuts off . so no more worries on hitting the rev limit.
tells u when nitorus is flowing
mastermind comes with a fuel pressure safty switch. turns nitorus off when or if ur fuel supply is low.
the coolest part i think makes ur nitorus work in stages meaning lets say u use 100 shot nozzle so when ur racing when u hit lets say 3500rpm a 50 shot will go first then then 4500rpm 75 shot, at 5500rpm the full 100 shot will spray all the way to redline.
and a few more cool functions.
hope this helps
Old Oct 11, 2001 | 02:18 PM
Ben Huynh's Avatar
Default Re: Nitrous Mastermind question (TEC2)
The Mastermind looks like it would work great in theory. From personal experience, it doesn't live up to it's claims.
Old Oct 11, 2001 | 02:28 PM
Zeus's Avatar
Default Re: Nitrous Mastermind question (ben@importparts.com)
what about the new one from Crane????
Old Oct 11, 2001 | 10:22 PM
TEC2's Avatar
New User
please share ur findings about it cause i dont wanna buy it then if its a piece of crap.
Old Oct 12, 2001 | 01:38 AM
Big James's Avatar
New User
It's JAMES! Hmm, maybe I am going to have to go over their literature I got a little closer. You could be right.
Old Oct 12, 2001 | 12:11 PM
TEC2's Avatar
New User
how so ben please rply.
thanks
IemSpooled219
May 13, 2009 02:57 PM
Tippyman
Nov 22, 2005 09:11 PM
SOHC_MShue
Nov 30, 2003 07:54 PM
allshownogo7
Feb 18, 2002 10:19 PM
