which timing belt to use.... ive already searched
question 1: if i put a b16a2 water pump on a b18c1 block with a b16a2 crank gear and a b16a2 tensioner and a b18c1 head, what timing belt do i use
question 2: same setup with the gears, and same block but a b16a2 head... which timing belt?
question 3: are the water and oil pump gears the same on a gsr as a b16a2
so basically in other words if i take all my accessories from my b16a2 and put them on a gsr block what timing belt would i use?
question 4: is the oil sucker on a b16a2 the same as a b18c1? or is the b18c1 longer to account for the longer stroke?
question 5: is the little shield looking thing the same, you know that piece you take off right before you get to the mains and rods
i know the oil pans are different, and thats cool, cause i already got a gsr oil pan. im just trying to solve the small stuff.
Re: (turbodohcsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodohcsi »</TD></TR><TR><TD CLASS="quote">ok, cause i heard that the b16a2 water pump gear had fewer teeth then the gsr. could just be hearsay......</TD></TR></TABLE>
wrong.... all b series vtec water pumps have 22 teeth... the ls have ?19? i belive.
use a gsr timing belt, with the b18a/b/c block/and vtec water pump.
ricanem1
01-23-2007 04:00 PM
