Turbo Issues
Old Apr 10, 2005 | 09:24 PM
WEldin4fun's Avatar
Default Turbo Issues
I am running a B18 and was running a Garrett T3/04E. I ran it for about 3k miles no issues except a little smoke when cruising at a constin RPM then let off and the turbo would smoke a little bit. I was running a -4 feed and a -10 return. I recently changed manifolds and went to a precision SC-61 and changed the Feed to a -3 like everyone says to run. The SC-61 lastested 20 mins on the dyno and then smoke every where. It now had shaft play up and down of 1 inch. So I pulled it of and threw the garrett back on. It lasted two days and now the same out come. Please any ideas what this can be? Car is on 28 psi and A.F is 12.1.
Thanks in advance.
Old Apr 10, 2005 | 11:10 PM
PrettyLude's Avatar
you have any kinks in your return line?
Old Apr 10, 2005 | 11:17 PM
96-EJ6 B18C's Avatar
Default Re: Turbo Issues (WEldin4fun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WEldin4fun &raquo;</TD></TR><TR><TD CLASS="quote">I am running a B18 and was running a Garrett T3/04E. I ran it for about 3k miles no issues except a little smoke when cruising at a constin RPM then let off and the turbo would smoke a little bit. I was running a -4 feed and a -10 return. I recently changed manifolds and went to a precision SC-61 and changed the Feed to a -3 like everyone says to run. The SC-61 lastested 20 mins on the dyno and then smoke every where. It now had shaft play up and down of 1 inch. So I pulled it of and threw the garrett back on. It lasted two days and now the same out come. Please any ideas what this can be? Car is on 28 psi and A.F is 12.1.
Thanks in advance.</TD></TR></TABLE>
Damn that is hardcore!!!
I have a similar problem, I run a 60 trim t3 with a -3 feed and a -10 return (not kinked) and it is water cooled to boot. It has been on my car for about three months and it starting to smoke a bit when the car is cold???
Old Apr 10, 2005 | 11:29 PM
WEldin4fun's Avatar
No kinks its Braid stainless line. I dont under stand what would cause this. I mean not only are the oil seals gone but from the shaft play the bearings have to be as well.
Old Apr 11, 2005 | 03:05 AM
oxSLEEPERxo's Avatar
Default Re: (WEldin4fun)
i hope your precision turbo is still under warranty, try a oil restricter next time, worth a try
Old Apr 11, 2005 | 07:37 AM
WEldin4fun's Avatar
Resticter On the -3? I never had this issue with the -4 excpet left off it would smoke a tad.
Old Apr 11, 2005 | 04:32 PM
WEldin4fun's Avatar
*bump*
Old Apr 11, 2005 | 07:26 PM
WEldin4fun's Avatar
anyone else? Please any help with this probablem.
Old Apr 11, 2005 | 07:27 PM
WEldin4fun's Avatar
Please any help? Someone had had to run into this probablem before.
Old Apr 11, 2005 | 07:28 PM
WEldin4fun's Avatar
Please anyone help? Someone has had to have ran into this probablem at one point
Old Apr 11, 2005 | 07:29 PM
WEldin4fun's Avatar
Ops sorry about the double posts. The board does not auto refesh the page after a post?
Old Apr 13, 2005 | 06:17 PM
WEldin4fun's Avatar
*bump*
91crxracer
Aug 20, 2006 03:23 PM
vtecspeed1320
Jan 31, 2006 09:15 AM
WEldin4fun
Welding / Fabrication
Apr 10, 2005 09:23 PM
GDM Z28
Mar 28, 2004 12:19 PM
Therumblingteg
Apr 19, 2003 12:20 AM
