Timing belt question
Old Sep 19, 2006 | 09:03 PM
underpressure02's Avatar
Default Timing belt question
I figured I would post this in here b/c I am always in this forum if it needs to be moved then so be it. Well this year could not have been any worse for me with motors, tonight on my way home my timing belt decides it is time to snap. The timing belt is only about 10-12K miles old new from honda. I did not have a chance to see if it rubbed on anything yet b/c it was pitch black outside and I had no light. I was driving down the highway at about 80 in 5th gear not beating on the car or anything and boom car shuts off.
What are the chances that motor is still good? Just humor me at this point in time b/c I am so dam pissed off.
So now I have no motor for the race car and can't race the daily driver.
Old Sep 19, 2006 | 09:15 PM
DxTrix's Avatar
Default Re: Timing belt question (underpressure02)
Friend did the same thing on the freeway and no damage was done....Hope nothing went wrong...good luck
Old Sep 19, 2006 | 10:49 PM
V-SPEC 1's Avatar
you have a 99% chance that your head/block is good.
Old Sep 20, 2006 | 01:36 AM
qfast817's Avatar
Default Re: Timing belt question (V-SPEC 1)
do you have cam gears?
Old Sep 20, 2006 | 04:13 AM
nasteboyii's Avatar
U COULD be alright chad
i had the same thing happen to me, but it ripped off 8 sets of teeth, right after i had pushed in clutch to slow down, put new belt on and it was good to go
good stuff
but make sure u check everything over see if something caused it
dan
Old Sep 20, 2006 | 05:32 AM
Default Re: Timing belt question (qfast817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">do you have cam gears?</TD></TR></TABLE>
yes skunk 2 cam gears
Old Sep 20, 2006 | 06:28 AM
93supercoupe's Avatar
bent valves at most, usually the failures when just driving turn out OK.
I remember i was driving in a nice G2 teg and it started popping and then shut off.
I thought it was the coil so I get another one and still no spark and just when I was getting pissed off, I walk to the other side of the motor, the T belt side and notice the cam gears not spinning when he was cranking the motor.
He only bent the intake valves I think and it was becuase we were cranking it to check spark.
Old Sep 20, 2006 | 06:42 AM
86si's Avatar
Default Re: Timing belt question (93supercoupe)
put a belt on it and hope for the best.
Old Sep 20, 2006 | 07:38 PM
vtekthis's Avatar
Default Re: Timing belt question (86si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si &raquo;</TD></TR><TR><TD CLASS="quote">put a belt on it and hope for the best. </TD></TR></TABLE>
but put a shirt on first youll prolly be ok
Old Sep 20, 2006 | 07:49 PM
Default Re: Timing belt question (vtekthis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">
but put a shirt on first youll prolly be ok </TD></TR></TABLE>
Oh the shirt was off as I was walking up the turnpike trying to find the dam mile marker number. Then beat my car with it when I got back.
That_jdm_ej2
Feb 4, 2019 06:58 AM
jtwoj1
Jun 5, 2015 08:24 PM
soodominican
Oct 12, 2008 08:59 PM
GSRSnowWhite
15
Oct 1, 2007 01:23 PM
TurboMiata
Dec 28, 2001 01:19 AM
