timing belt issues
Old Aug 4, 2012 | 04:21 PM
  #26
---NON-VTEC---'s Avatar
Default Re: timing belt issues
Originally Posted by TKERacer619
Yea, thats no good. Check the gears for irregular wear. Any idea on the condition of the motor? I am assuming the valves are done
I've seen people tension timing belts with 2x4s and not do that. As long as all the parts are in the right place I seriously doubt its an install error. I would suspect a poorly machined part since you say everything is new. Are they factory parts?
yes i have bc valves, had the head ported and resurfaced. As for the bottom end crower rods, crank and cp pistons. water pump and gears are from honda new
Old Aug 4, 2012 | 04:25 PM
  #27
Here are some pics of the belt
Old Aug 4, 2012 | 06:11 PM
  #28
wunfstgsr's Avatar
Loved
Community Favorite
seems like the belt is too tight or the wrong size??
Old Aug 6, 2012 | 10:53 AM
  #29
if its the wrong size it woundnt even fit.
Old Aug 7, 2012 | 11:25 AM
  #30
wunfstgsr's Avatar
Loved
Community Favorite
well if its a b16 belt on a b18-c1 gsr it would be a bit smaller.. or your tentioning it too much some how, or its skipping teeth so much its grinding the inside of the belt away. How does the oem cam gear teeth look them selves?
Old Aug 8, 2012 | 01:02 PM
  #31
i know on a gsr belt it has a 127 teeth and on a ls its 126. yeah when it was running the belt on the backside moved back and forth at the idol. then around 3 grand it would stop. they are good
Old Aug 9, 2012 | 02:35 AM
  #32
shanebadoo's Avatar
Actually gsr belts have 126 teeth and the gates number is t247rb. Just make sure you have the right belt.
3s1k
Sep 27, 2010 01:58 PM
Ge-money
Mar 24, 2010 06:35 AM
timlush
Jan 9, 2007 04:22 PM
grngsr01
Mar 14, 2005 05:19 AM
petrv
Jun 20, 2003 12:23 PM
