Tial wastegate help..
Old Jan 14, 2002 | 03:05 PM
maxim's Avatar
Default Tial wastegate help..
I just installed my Drag III kit this weekend and I think my Tial is staying open all the time. The reason I think this is because I can see exhaust coming out of the dump tube. I have a line coming from the side port of the Tial t'd with my Greddy BOV line going into the side of the turbo compressor. What could be causing this?
Old Jan 14, 2002 | 03:29 PM
dustin's Avatar
Default Re: Tial wastegate help.. (maxim)
Did you install the metal ring between the wg and the manifold that tial included?
Dustin
Old Jan 14, 2002 | 03:42 PM
Doodoo's Avatar
I think your BOV should be teed to AFTER your throttle body.
Old Jan 14, 2002 | 03:43 PM
dustin's Avatar
Default Re: Tial wastegate help.. (Doodoo)
He's right.
Old Jan 14, 2002 | 03:53 PM
D-SPEED's Avatar
Default Re: Tial wastegate help.. (dustin)
yes.
keep the tee from the WG side port going to your compressor.
have the BOV vacuum line POST throttle plate. try that and see what happens
Old Jan 14, 2002 | 03:56 PM
maxim's Avatar
Well, at first I had the little ring that came with it installed but it did not fit into the hole on the wg flange, therefore not sealing completely onto the flange. So I ended up taking it off so there would be no gap between the manifold and the bottom of the wastegate. Could there be a problem inside the Tial?
I have the Greddy BOV and the port on the top has a line going to the FPR vac line, but there is a bottom port that I ended up t'ing with the WG going into the side of the turbo compressor.
Old Jan 14, 2002 | 03:57 PM
dustin's Avatar
You have to install the ring. It sits flat when you tighten the WG down.. the wastegate is spring loaded.
Dustin
Old Jan 14, 2002 | 05:03 PM
threatcon13's Avatar
New User
Dustin
yup i had the same problem...its the metal ring for sure.
Old Jan 14, 2002 | 05:35 PM
D-SPEED's Avatar
Default Re: Tial wastegate help.. (turbo01gsr)
that ring is not supposed to fit into your WG flange. As stated above, it is supposed to seal the plunger inside the WG when fully tightened down. Make sure you put it in the right way, it should fit very "snug-ly" into the WG port
Old Jan 14, 2002 | 06:20 PM
maxim's Avatar
Default Re: Tial wastegate help.. (D-SPEED)
Thanks guys, I just put it in the wrong way
Old Jan 14, 2002 | 11:09 PM
MiraiZ's Avatar
don't feel bad...it happend to me too
Cloneufc
May 5, 2009 04:59 PM
kfar09
Jul 9, 2004 07:16 PM
patdemps
May 16, 2004 10:06 AM
Ricey McRicerton
Sep 23, 2003 04:04 AM
safe driver
May 1, 2002 02:44 PM
