TIAL wastegate?
Old Sep 5, 2003 | 02:23 PM
booscivic's Avatar
Default TIAL wastegate?
I got a tial 35mm 11psi spring, can I tuned the boost down with avcr and also can I use it with no dupmtube? Thanks for all your help
Old Sep 5, 2003 | 02:28 PM
u2civic1's Avatar
Default Re: TIAL wastegate? (booscivic)
i don't think u can boost controllers only let u turn the boost up from the spring
Old Sep 5, 2003 | 02:30 PM
Kamin's Avatar
Default Re: TIAL wastegate? (u2civic1)
as far as i know, that is true
you cant run lower boost than the spring in the wastegate.
Old Sep 5, 2003 | 02:31 PM
LsTurbo91's Avatar
You can lower it by trading with my 6psi spring hehe.
Old Sep 5, 2003 | 02:34 PM
boost fed ls's Avatar
you can use a avcr to turn up and boost but you cant go below what the spring is set for, as for the dump tube you can leave it open but you run the risk of melting wires, ac lines, ect.
_Cyclone_
May 4, 2005 02:32 PM
Harassing Herbs
Mar 1, 2004 08:31 PM
Cyber ITR
Jan 19, 2004 03:38 AM
DOHCarp
Jun 29, 2002 11:30 AM
wonny
May 30, 2002 03:18 PM
