Tial Springs
Old Oct 26, 2005 | 06:36 PM
Dunc's Avatar
BCICAN
Default Tial Springs
What would be an "acceptable" range of output for a tial spring? In particular the 38mm Big Yellow along with a small green? According to their site it should make 17.4psi, but datalogging shows 14.2-14.4psi. I try the yellow/blue too and same outcome.
There are no boost leaks, and everything holds steady...its just like 3psi off whether I hook into turbo or intake for a pressure source. Has anyone else had this problem? I find it odd that two spring combinations yielded similar results.
Old Oct 26, 2005 | 06:38 PM
2k.civic.si's Avatar
Default Re: Tial Springs (Dunc)
another possibility is the sensor your using to measure psi is off? just a thought...
Old Oct 26, 2005 | 07:10 PM
Dunc's Avatar
BCICAN
Default Re: Tial Springs (2k.civic.si)
that is possible. I'm using the GM 3 bar. My autometer boost gauge (even though I don't trust it 100%) reads about 18psi with the yellow/blue springs. Boost cut happens at 22-24psi on the guage but it set at 18.5 in hondata. 18psi from the 3bar reads 20 on the autometer. I guess I'll just try the big green/small yellow and see if that fixes things.
94eg5squadMD
Mar 6, 2016 01:29 PM
areyouasian
Nov 20, 2009 08:14 PM
00trdtaco
Oct 9, 2008 01:03 AM
building boost
Dec 7, 2006 12:51 PM
Civic TSI
Aug 8, 2004 03:00 AM
