Tial blow off valve problems
Old Aug 24, 2006 | 05:15 PM
o'malley_808's Avatar
Default Tial blow off valve problems
Hey, just installed my peakboost kit, runs awesome and pulls hard, My blow off valve though is getting sucked 1/2 open at idle though. This is on a built b20/vtec. The Bov is closed when the car is off but as soon as i start it, you can watch the BOV open as the vacuum builds. I am also getting a little bit of compressor surge when no at WOT and letting off. I'm running about 12psi on a t3/tO4E. Anyone else using a different spring? How do I fix my problem?
Old Aug 24, 2006 | 05:29 PM
97turbols's Avatar
Default Re: Tial blow off valve problems (o'malley_808)
What spring are you using? Here is the chart from tial:
Engine Vacuum Reading...........Use Spring
- 22 and -23 in/Hg................-12 Psi (-24 in/Hg )
-18 and -21 in/Hg.................-11 Psi (-22 in/Hg )
- 14 and -17 in/Hg................-9 Psi (-18 in/Hg )
-10 and -13 in/Hg.................-7 Psi (-14 in/Hg )
match the vacuum ur car pulls at idle to the correct spring
Old Aug 24, 2006 | 05:30 PM
Soccerking3000's Avatar
its normal for it to be open at idle, as for youy getting compressor surge, does it have a good vacuum source? Also the tials arent adjustable without changing the spring but i think you'll be fine with a little surge it never hurt anyone
Old Aug 24, 2006 | 07:25 PM
awdgsx96's Avatar
Default Re: Tial blow off valve problems (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">its normal for it to be open at idle, as for youy getting compressor surge, does it have a good vacuum source? Also the tials arent adjustable without changing the spring but i think you'll be fine with a little surge it never hurt anyone</TD></TR></TABLE>
Yeah I know I'm the n00b, but wouldn't spending $200 on a BOV and still have compressor surge defeat the whole purpose of it?
Old Aug 24, 2006 | 09:25 PM
Crab-Cakes's Avatar
Mine also stays open at idle..I think thats just normal...And mine is run right off my GE vacuum box...
Old Aug 24, 2006 | 10:08 PM
VRD^don's Avatar
Default Re: (Crab-Cakes)
12psi spring here..and no problems at all
SAXON
Jul 29, 2010 11:09 AM
Legion_2
Apr 10, 2009 08:07 PM
got wide
Oct 20, 2008 09:16 AM
Jonny Black
Sep 13, 2005 07:58 PM
ThePro
Jun 30, 2005 04:43 PM
