Throttle plate keeps getting stuck
Old Feb 5, 2004 | 04:45 PM
genop's Avatar
Default Throttle plate keeps getting stuck
I just swapped a d16z6 into my 97' civic and it ran fine for about a day, but now when I let off the gas really fast the throttle plate will get stuck open just a little bit so that it idles at like 1500 rpms. I can fix it by tapping the gas, but it's just annoying. Anyone had this problem?
Old Feb 5, 2004 | 04:50 PM
rtype11's Avatar
Default Re: Throttle plate keeps getting stuck (genop)
throttle cable may be gummed up remove and run a solvent through it WD-40, gunk may clear it up, check that the throttle cam and spring are clean and lubed, the TB plate itself may be gummed/carbon'd up, remove and clean carefully many solvents are not sensor safe.
Old Feb 5, 2004 | 04:54 PM
Jdm93civic's Avatar
clean it....
Old Feb 5, 2004 | 04:57 PM
genop's Avatar
Default Re: (Jdm93civic)
yea, I am going to clean it tomarrow and see if that helps. It doesnt look real dirty though.
Squidwerd
Aug 15, 2013 01:30 AM
BLKFLSH
Sep 22, 2009 05:49 PM
OneCrzySetup
May 25, 2008 08:51 AM
obd1_crx
Jun 12, 2007 05:42 AM
rolledthatho
Sep 15, 2005 01:02 PM
