For those running thicker headgaskets, how does it affect cam timing?
Old Dec 12, 2003 | 04:40 PM
yellow blur's Avatar
Default For those running thicker headgaskets, how does it affect cam timing?
Do you guys have to adjust your cam timing to compensate for the thicker headgasket? Also, is there anything you guys have to worry about when installing a head while using a thicker headgasket, like torque specs or anything? I figure you guys would know because a lot of people in here would use thicker headgaskets to drop their CR's. Thanks.
Ed
Old Dec 12, 2003 | 04:59 PM
Jared's Avatar
Default Re: For those running thicker headgaskets, how does it affect cam timing? (yellow blur)
Cam timing gets retarded with a thicker gasket. This can be accounted for with the gears, but amount depends on how much thicker the gasket is than stock. Torque specs on the head bolts should remain the same.
Old Dec 12, 2003 | 06:08 PM
drvfast's Avatar
you can hardly notice the difference
Old Dec 12, 2003 | 06:29 PM
Default Re: For those running thicker headgaskets, how does it affect cam timing? (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">Cam timing gets retarded with a thicker gasket. This can be accounted for with the gears, but amount depends on how much thicker the gasket is than stock. Torque specs on the head bolts should remain the same.</TD></TR></TABLE>
Does this mean that you would have to use the gears to advance it back to what it was previously at? How much advance if so +1, +2?
D16SohcVtec
Dec 31, 2007 11:00 AM
rol1in0n20s
Nov 25, 2007 08:27 AM
N1 Andy
Nov 4, 2006 01:32 PM
turbochic
Apr 24, 2003 07:29 PM
