To those people running an MSD setup... SIMPLE questions...
Old Aug 23, 2003 | 01:20 PM
TRE_'s Avatar
Default To those people running an MSD setup... SIMPLE questions...
I'll make this simple: can you run JUST a modified distributor cap and blaster 2 coil? Or do you NEED a ignition module(SCI, 6a, etc)? Would just running the coil be helpful?
Thanks
Old Aug 23, 2003 | 09:15 PM
TRE_'s Avatar
Default Re: To those people running an MSD setup... SIMPLE questions... (glowing_turbo)
bump
Old Aug 23, 2003 | 10:34 PM
nevin's Avatar
bump.
I was about to post this same question cause I have a Blaster 2 coil and picking up my msd cap tomorow but don't know if the 6a box is required or if just the blaster coil will help the spark.
Old Aug 23, 2003 | 10:42 PM
DLOTYPER's Avatar
i always asked my self the same question,,, but think about it like this,,, you have to remove the factory coil and run the rpm signal and power (or something) to the msd box, so i would say you prob have to use the msd box, thats my guess,, but im not completely sure
Old Aug 23, 2003 | 11:10 PM
HYBRID_H@TCH's Avatar
Default Re: (DLOTYPER)
you can run just the coil and cap..hell Iam doing it right now till my 6a comes in.
Old Aug 24, 2003 | 12:04 AM
TRE_'s Avatar
Default Re: (99Hybrid_Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">you can run just the coil and cap..hell Iam doing it right now till my 6a comes in.</TD></TR></TABLE>
How did you hook up the coil? as in what wires did you run to it from where?
Old Aug 24, 2003 | 12:09 AM
Default Re: (glowing_turbo)
take the stock coil out..take the 2 wires that went to the coil..add a few feet of wire to them (cut off ends and solder the new wire on) notch the cap a little bit so wires can run thru..put cap back on..run wires to the coil..connect..run coil wire to the cap..start car and enjoy.
Old Aug 24, 2003 | 10:53 AM
nevin's Avatar
thanks.
Old Aug 24, 2003 | 11:40 AM
TRE_'s Avatar
Default Re: (nevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin &raquo;</TD></TR><TR><TD CLASS="quote">thanks. </TD></TR></TABLE>
word. thanks for your help.
turboH22Aakkord
Jul 26, 2005 10:08 AM
ridexstraight
Nov 15, 2004 05:21 PM
_oemek_
Aug 16, 2004 04:16 PM
SIK IN DA HED
Jul 31, 2001 01:25 PM
