thinking of going lsv turbo
Old Aug 8, 2010 | 07:08 PM
phaphon's Avatar
Default thinking of going lsv turbo
hey im new to fi...my first turbo car was b16 turbo with itr valve springs and sk2 tuner1 cams and sk2 manifold first gen..i bent some valves so i took it out and im in the process of reffing my ls
ok after im done reffing i want to start on my lsv turbo im planning on just buying new super tech flat valves and slapping the head on thinking if i should rebuild the ls bottom end with arp rod bolts new rod bearings ofcourse and rings...or should i get forged rods/piston..my goal is to be at around 300 to 400 whp..any iinfo on what else is needed of is appreciate thanks
my kit is a turbonetics turbo with 750 rc intjectors will be buy a six puck clutch and fuel pump
Old Aug 8, 2010 | 08:27 PM
phaphon's Avatar
Default Re: thinking of going lsv turbo
any help ???
Old Aug 8, 2010 | 11:00 PM
civickiller's Avatar
My lsv bone stock head and block made 266@8psi. If you want it to last then put forged part but I also think between 300-400 hp will last for a while. If you can get another ls block and build it on the side
Old Aug 8, 2010 | 11:13 PM
projectcivicjp's Avatar
which turbonetics turbo is it? Is there any particular reason you are going with flat face valves? I would suggest staying with the dish style. Flat face is specific to N/A builds from what I've seen. Someone else might have some more information on that later on. I would go ahead and go with forged internals that way you can go from there and upgrade at a later date with your setup if you so choose to
Old Aug 8, 2010 | 11:28 PM
CivSiClone_96's Avatar
I just rebuilt my lsv did new bearings rings and honed the block I made 315whp on 10psi using a garrett 57 trim and a ramhorn manifold.
Old Aug 9, 2010 | 02:03 PM
phaphon's Avatar
welll for the turbo the only marking on it i see is a red T i think im not sure have not look at it in a while..the reason im going with flat valves i didnt think it would hurt since i seen someone with a build thread using it and would a picture of the snail help you determine what kind it is ? i ask b4 didnt really get a answer let me know ill post a pic if it will help
Old Aug 9, 2010 | 02:05 PM
phaphon's Avatar
cool i would love to be somewhere around there but what was your whole set up? did you have to get a new fuel pump? what tranny were you using was the head stock?
b20hatchek
Apr 29, 2013 05:32 PM
804k20
Nov 5, 2010 03:09 PM
blakh
Dec 16, 2007 11:46 AM
3k9civic
Apr 21, 2006 06:52 AM
b20vtechatch
Mar 18, 2006 06:01 AM
