Is the thing on the end of the fuel rail needed? dampner???
Old Mar 6, 2004 | 08:17 PM
turboex's Avatar
Default Is the thing on the end of the fuel rail needed? dampner???
Ok using a AEM fuel rail and the stock setup uses a fuel dampner at of the rail where the line comes in. Reason I ask is because the motor has the crazy "honda" idle that whats to go from 700-1300rpm. This is using a hondata, dsm injectors and resistors. Also the vacumm is running at 19 or in that area. thanks for any help in advance.
Old Mar 6, 2004 | 08:52 PM
SOHCArchangel's Avatar
Default Re: Is the thing on the end of the fuel rail needed? dampner??? (turboex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboex &raquo;</TD></TR><TR><TD CLASS="quote"> crazy "honda" idle that whats to go from 700-1300rpm.</TD></TR></TABLE>
sounds like a bad FIV
Old Mar 6, 2004 | 09:57 PM
turboex's Avatar
Default Re: Is the thing on the end of the fuel rail needed? dampner??? (SOHCArchangel)
whats that? You mean an IACV?
Old Mar 7, 2004 | 06:04 AM
DaX's Avatar
DaX
Loved
Community Favorite
FITV = Fast Idle Thermal Valve
It's located under the throttle body and has coolant lines going to it. Take it off and rebuild it. Do a search for fast idle vavle for directions on how to do it.
Old Mar 7, 2004 | 08:33 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboex &raquo;</TD></TR><TR><TD CLASS="quote"> the stock setup uses a fuel dampner at of the rail where the line comes in. </TD></TR></TABLE>
All the fuel pulsation damper does is help reduce noise from the fuel system. It wont cause a running problem.
nihad
Jul 11, 2009 08:17 AM
LSDA9Nick
Jan 27, 2008 09:59 PM
boostedK20a2
May 3, 2006 08:31 AM
thehondaguru
Apr 20, 2004 08:51 AM
dubxl152
Jan 18, 2003 02:42 PM
