thicker head gasket help
Old Jul 30, 2009 | 04:54 AM
wambus's Avatar
Default thicker head gasket help
My son and I are repairing his boosted 95 Civic. He ordered pistons, but they are slightly highter compression than factory, so he determined that he needed a thicker head gasket to lower the compression a bit. What thickness is factory? What thickness should he get? What else may be affected by this... what about the timing belt? We are planning on doing this ourselves, so I want to get all the info I can before we start screwing things up...
Old Jul 30, 2009 | 05:15 AM
kyden's Avatar
Default Re: thicker head gasket help
what compression pistons are they? he might be alright.
Old Jul 30, 2009 | 07:01 AM
wambus's Avatar
I bellieve that they are 9.2:1. Is that higher than factory? Is it worth adding a thicker gasket?
Old Jul 30, 2009 | 07:02 AM
kyden's Avatar
that compression ratio is fine. its probably not higher than factory.
vtekthis
Nov 2, 2004 07:17 PM
fastludeh22
Oct 14, 2002 01:52 PM
you2envious
May 26, 2002 06:26 PM
